Now its quite a ....fine wine
Started Feb 21, 2021 | User reviews
KoolKool Regular Member • Posts: 263
7
Got used one but its a like new cosmetic and glass
Working well on EM1 Mk2, this is what my experiences
Pros:
- Small and compact, stylish form factor
- PRO-like color, contrast rendition
- Fast AF
- Very well metal build quality
- Very good flare resist
- Sharp! (but...there are cons)
Cons:
- "Field curvature" cause softness issue on corner (My copy is soft on right corner)
- Not weather seal
- The MF ring switch wont active Focus Peaking
- Starburst only start well-shaped from F8 above
- Still less friendly price
Tips: When taking landscape, you want to reduce field curvature and sharpen up the "flawed corner", i recommend set the focus on that corner, aperture at F4-F5.6.
I get much sharper right corner by doing this, center is sharp as well, a minor loss sharpness at left corner but still decently sharp!. Good coping!
View from my house, its a boring shot, i hope to get more meaningful photos when i have chance to go outside
Olympus M.Zuiko Digital ED 12mm 1:2
Wideangle prime lens • Micro Four Thirds • V311020BU001
Announced: Jun 30, 2011
KoolKool's score
4.0
Average community score
4.3
Olympus E-M1 Olympus M.Zuiko Digital ED 12mm 1:2
Danielvr Veteran Member • Posts: 6,863
Re: Now its quite a ....fine wine
Cons:
Field curvature as such does not cause unsharpness (except when you photograph 2D objects like test charts).  It just moves the focal plane a little to the front or back, so that other parts of the scene -that lie nearer or farther- are rendered sharp.
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
108 Senior Member • Posts: 1,353
I don't use mine as much as I should , and every time I think of selling it I put it on my Em1 and the little lens reminds me how good it is : sharp and sweet at the same time, renders as nicely as my old 4/3 11-22
I just wish it was 10 mm .......
 108's gear list:108's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus OM-D E-M10
Impulses Forum Pro • Posts: 10,039
Laowa 10/2 enters the thread
I thought about replacing my Laowa 7.5/2 & Oly 12/2 with the 10/2 since I'm not using either a ton and I've grown to really like the 20mm EFL on another format, but ehh... The niche cases I'd use them for these days favor the wider or AF options, and there isn't much to gain in selling them to buy the 10mm.
I bought my 12/2 refurb, I wish Oly had lowered the price over time since it fills a nice hole in the system but the vast majority of people end up turned off by the retail price.
@OP: Try a Contax GG-2 (or the JJC/Kiwi copy) if you want a more compact alternative to the thumbscrew OEM hood, there's nifty slip on caps for the former too.
https://imgur.com/2rHwHgL
https://imgur.com/HqlZyGo
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
Agree with your findings except, like Daniel said, you are probably not looking at Field Curvature, but a misaligned ("decentered") lens. I had several of those and finally gave up on the Oly 12/2. For it's price it should certainly not be such a widespread issue.
I had the Roki 12/2 which comes with its own set of disadvantages, but it was very sharp corner to corner. The two "Pro" zooms, the Oly 12-40 and Pana 12-35, cover that FL really well. Of course they are not as compact...
The Laowa 10/2 is tiny and sharp, albeit only MF.
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
Dunsun Contributing Member • Posts: 656
Hey,
Your very lens is decentered. Even though field curvature is also problematic on many samples of this lens. I have had 3 of them. 2 were decentered, 1 had an issue with a severe field curvature. Fortunately the last one was great.
As you have said it produces amazing colors. I really love its rendering signature.
Anyways there is only 1 wider lens that produces similarly amazing look (Voigtlander 17.5mm 0.95 but it has to be stopped down to F4. Wide open or close to it produces too cold images).
Cheers
Bassam Guy Veteran Member • Posts: 4,890
Agree. I got one for a good price from a friend of mine in Brooklyn who works at a camera store. B&H is still asking $700? It is a nice lens but I paid less than that for my 12-40 that's only one stop slower.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
OP KoolKool Regular Member • Posts: 263
thanks people for comments!
aw man....my len is decentered....
i will contact the seller for the issue, hope to get another better copy...
just have a hope
Albert Valentino Veteran Member • Posts: 9,770
just have a hope
One quick test is to shoot the same thing with your camera upside down - focusing oj exactly the same spot. Then compare.
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
just have a hope
Thanks for this - a great solution for identifying lenses with problems.
Hope you'll not mind if I take the liberty of your signature line....
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
