In praise of the RF 35 and high ISO on the R
Started Feb 20, 2021 | Discussions
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
6
I was sitting at my desk a couple of days ago, when my cat jumped up into my lap and looked up at me. On impulse, I picked up my R, which was on a table next to me, with the RF 35 mounted, turned it on and took off the lens cap as I lifted it to my eye. By the time I got it to my eye it was ready to shoot, so I took a couple quickly. It was in tracking mode, with initial point set at the center, so I just positioned that on his eye and fired off a couple of shots before he looked away. I didn't have time to check the settings. It was in Av, with F2.8 and a minimum shutter speed of 1/250 (I've forgotten what I was shooting previously) in auto ISO, which gave an ISO of 16000 at 1/320. I was amazed by how well it came out, considering the ISO. I then switched the aperture to F1.8 and set the minimum speed to 1/125, and got a couple of other shots. Here are the two:
Not only am I impressed by the high ISO performance of the R, but also by the performance of the RF35. I used to own the EF 35 F2 IS, which I sold when I bought my R, and replaced with the RF version (I stopped using the EF 35 on my M cameras when I got the superb EF-M 32). The EF 35 was a fine lens, but it couldn't have taken these shots. That's because of the close focusing ability of the RF lens. The EF lens wouldn't have been able to focus this close. Not only did the RF lens focus this close, but it also focused really fast, which is unusual for close distances.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
Re: In praise of the RF 35 and high ISO on the R
Wow that is really cool.  I have the RP and when I shoot with the RF 35 1.8, I usually shoot manual, with a slow shutter speed and high Av to bring out detail.  Works pretty good, for sleeping dogs, anyway.
Below is one I shot at 1/125 of a second, F2, ISO 12800, and one shot at 1/13 of a sec, f7.1, ISO 10000.
Where is my treat?
It is exhausting being a dog.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
Occams Razor Senior Member • Posts: 1,252
The EF 35 has a MFD of 9.45" (24cm) and the RF 35 has a MFD of 6.69" (17cm) so while the RF is an improvement, the EF 35 f/2 was pretty good to begin with.  In any case, glad you are enjoying the lens.  I'm enjoying mine.
Randy
 Occams Razor's gear list:Occams Razor's gear list
Canon EOS Rebel SL2 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +4 more
Alastair Norcross
OP Alastair Norcross Veteran Member • Posts: 9,874
Yes, I know it’s only about 3 inches closer, but when the cat is on your lap, that 3 inches makes all the difference.
Alastair
RDM5546
RDM5546 Senior Member • Posts: 3,654
I also like the close focus of the RF 35 and the excellent IS performance of that lens. With that said I usually default with RF24-240mm lens on R and use the RF35 on my R5 more.
The RF 35 obviously is more versatile indoors though.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
SteveinLouisville
Yeah, the three inches is a big deal when shooting pictures of dogs or cats.  The nose is in focus.  Sort of.
I am ready for my close-up!
thunder storm Forum Pro • Posts: 10,139
Acceptable results at higher ISO is the full frame advantage. With my M50 I had to work really hard sometimes to get a good exposure. With the R I'm getting lazy.  There's 1/8000th and a drop in ND-filter on one side of the spectrum, and ISO 1250 on the other. That's a huge margin in AV-mode, and on top of that there's a minimum shutter speed to save your butt  if you forget watching the shutter speed.
Full frame is for amateurs, it's aps-c requiring a skilled photographer.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Alastair Norcross
LOL. But now you have the M6II, you have a couple of those things on APS-C too. The M6II auto ISO has the same minimum shutter speed implementation as the R (and the 7DII). And you can actually use a faster shutter speed on the M6II with e-shutter than on the R. I have used 1/12800 a couple of times to allow me to shoot at F1.4 in bright light. I was surprised to discover that the R tops out at 1/8000 in e-shutter.
Alastair
Oh yeah, that's great. I totally forgot about that. That's great with the 32mm, but with my f/1.8 glass it's very usable too.
Are there any downsides for e-shutter?
The 32Mp aps-c sensor is newer tech.
Alastair Norcross
You can only use it in single shot drive mode, or RAW burst mode, which is cropped to 18MP and needs DPP to extract the images, I think (I still haven't tried it, but keep meaning to). I don't think you can use flash with it. It can result in banding in some artificial lighting, so you need to test that first. I have used it indoors quite a lot, but there are some rooms where the lighting causes banding. Still, I find it very useful, and use it a lot. It's great for candid shooting using the screen tilted up. I also find I can shoot quite fast with it, even though it's only one shot at a time. At least 2fps with successive shutter presses. It probably has some rolling shutter too, but I've never used it in conditions where this would show up.
That's true. I hadn't thought of that as the reason.
Alastair
That's fine. I almost never shoot burst mode. Did that with my 70D and I'm done with it. When le moment décisif needs to be chosen in post you need to many pictures.
I'm not really interested in using flash and 1/12800th of a second at the same time. I will also use the R when I need a flash. But thanks for mentioning it anyway.
I'm thinking about a C mode for low light and a C mode for lots of light. Sounds to me like silent mode is good enough in lots of light situations.
Rik_C Junior Member • Posts: 28
The RF 35mm f/1.8 is a great lens that I have on my R6 a lot. The only thing I'd say it's not good for is video especially run and gun. For that it focuses too slowly and there is too much focus breathing and I typically put my 24-105mm F/4 L on the camera which focuses quickly and smoothly and is just a great lens for shooting video and versataile in general IMHO. But off-course it comes nowhere near in terms of depth of field and close focusing ability!
