Canon EOS M3 Ring Flash
Started Feb 19, 2021 | Questions
Dental Photography Newbie New Member • Posts: 1
I hope someone can help me....
I have a Canon EOS M3 and Im looking for a ring flash for dental photography. I have a suitable 105mm Macro lens but my budget does not currently stretch to the Canon branded ring flashes. I hope can recommend a non canon, compatible ring flash which will suit my needs for now?
I bought a Neewer ring flash but I don’t think it is compatible. The camera is not giving me the option to enable the flash and on selecting external flash settings it says the flash is not powered on or is not compatible.
Any advice would be greatly appreciated.
Canon EOS M3
Dors
Dors Regular Member • Posts: 320
Re: Canon EOS M3 Ring Flash
Probably not suitable for your current budget and probably you know already, but just for mentioning, Canon EF-M 28/3.5 macro lens has built-in ring light and is affordable and has high optical quality.
 Dors's gear list:Dors's gear list
Canon EOS M6 Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM
AKRover Regular Member • Posts: 289
I have a Nissin MF-18 Ring Flash.  I do not know if there are compatibility issues with any of the M bodies.  I have used it with a few different Canon bodies, but I haven't tried it on my M6II.  Nissin's compatibility chart is hit and miss on camera models but I don't see any M's listed.  Compatibility would be the only concern I would have in recommending it.  It is a remarkable piece of equipment.  It probably offers a lot more adjustability and control than your application requires, but it is cheaper than the Canon products (but still pretty expensive).  Nissin makes good quality products.  If I get a chance tomorrow, I will test it on my M6II and let you know if I find any issues.
 AKRover's gear list:AKRover's gear list
Canon EOS 5D Mark III Canon EOS 1200D Canon EF 50mm F1.8 II Canon EF 100mm f/2.0 USM Canon EF 200mm f/2.8L II USM +8 more
I ran my Nissin through some quick tests on the M6II and found no compatibility issues.  It exposed perfectly in TTL mode.  It fired in manual mode.  What that means for your camera is inconclusive, but at least we know that it is compatible with some M bodies.
Cheapo Marx
Cheapo Marx Senior Member • Posts: 2,543
How about this for $299?
https://www.dpreview.com/products/canon/lenses/canon_m_28_3p5_is_stm/overview
On a Planet of Eight Billion, We're In a Pretty Nice Bubble.
