Wireless shutter release SDQ+SDQH
Started Feb 18, 2021 | Discussions
motomanDK
motomanDK Contributing Member • Posts: 917
Hi all
for my SD14 + sd15'th i have used wireless release for many years. But can it really be true, that i can't get that for my SDQ and the SDQH?  I have the CR-31 cable release that works fine.  I have bought a CR-31 cable between the 'old' JJC wireless system i use for the older SD's.  This works perfectly on a DPQ3 - but NOT on the SDQ/SDQH.
Has anyone solved this mystery??????
/Henrik - Denmark
(SD14 and 2 * SD15 and SD-quattro and SDQH ... and about 7 kg glass)
 motomanDK's gear list:motomanDK's gear list
Sigma SD14 Sigma SD15 Sigma sd Quattro Sigma sd Quattro H Sigma 10-20mm F4-5.6 EX DC HSM +9 more
Sigma SD14
sambaba Forum Member • Posts: 85
Re: Wireless shutter release SDQ+SDQH
https://www.dpreview.com/forums/thread/4259676
Searched and found this thread. Perhaps it helps
 sambaba's gear list:sambaba's gear list
Sigma DP2 Merrill Fujifilm FinePix S5 Pro Sigma SD1 Merrill Nikon AF Nikkor 50mm f/1.8D Sigma 150mm F2.8 EX DG OS Macro HSM +2 more
Jeffry7 Contributing Member • Posts: 898
I use a wireless remote from JJC.
http://jjc.cc/index.php/Product/product_info/id/2544
It is in two parts. One is the wireless remote. The other mounts in the camera hotshoe and plugs into the shutter port on the side of the sdq.
The trick is to get the right cable. But the same device can support several camras, just switch the cable as required.
Scottelly
Scottelly Forum Pro • Posts: 18,026
motomanDK wrote:
Hi all
Is this the JJC wireless remote you have?
https://www.amazon.com/JJC-ES-628I2-Wireless-Controller-replaces/dp/B00W56WOHO
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
motomanDK
OP motomanDK Contributing Member • Posts: 917
I am really sorry guys .........
I absolutely don't know the reason behind this mystery - i even borrowed a DP3Q to test earlier - with the result, that it worked on the DPQ and NOT on the SDQ's.
Today i just connected the 2 Yongnuo RF-603C II and the camera (SDQ) with the JJC Cable-I2 (CR-31 replacement) ........ AND IT JUST WORKS!!!
Sorry to ask before i tested again - the reason it was relevant again, is my focus stacking experiments (https://photos.app.goo.gl/ebfF5VEhMnfyv9MZ9) . I guess perhaps the reason that it suddenly works, could be a change in a firmware release for the cameras??
Thank you for all your replies.
/Henrik - Denmark
motomanDK
Re: I am really sorry guys .........
UPDATE - i now realize what the issue was/is - during my test earlier today, i only tried manual focus.  If i switch to Auto focus on the lens, as soon as i switch on the camera, it starts auto focusing.
Even if the cable (JJC I-2) is ONLY plugged into the camera, the camera think that the release button is pressed half-way down.  THAT was what worked correctly with the DPQ and not with the SDQ!!
/Henrik - Denmark
