Help calculating FOV for instant camera
Started Feb 18, 2021 | Discussions
crandallwarren New Member • Posts: 7
Hi all,
Can anyone help me with the math on this? I have an Instax camera with a 38mm lense. The problem I’m having is that the image the lense captures is quite a bit wider than that seen through the viewfinder. This becomes a real issue when trying to isolate a certain element in a shot: say a door front, a sign etc.
I was trying to figure out a way that I could calculate the rough area of capture based on the lens length and the distance from the subject. So that, for example, if I measured a door that I want to fill the frame with, I could run some kinda calculation based on the width of the door that would tell me how far away the lens should be. Is this possible?
I’ve played around with some calculators and equations online, but haven’t gotten very far.
The image size of Instax mini film is 46x62mm. The lens is 38mm.
Thank you!
C.
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: Help calculating FOV for instant camera
crandallwarren wrote:
Hi all,
Much easier than that.
Take a photograph of some easy scene (e.g., brick wall) at a known distance. What you want to do is make a pair of wire frames to mount on the camera and look through for framing. Adjust the spacing between the wire frames so that when your face is up against the rear one, the view outlined by the front one matches what your photo shows. No formulas, etc.
If it were me doing this, I'd 3D-print the frame rather then bending wire. I'd use rectangular holes cut in paper to determine the spacing for the 3D-printed frame elements. Still, there's nothing wrong with bending wire....
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
Which camera is this? 38mm sounds very wide for the Instax Mini format, and would be equivalent to an ultra-wide 21mm on a 35mm film camera.
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
