Anyone can help with a Maxxum/Dynax 7 problem?
Started Feb 16, 2021 | Questions
User2518922339 New Member • Posts: 9
I bought a used Dynax 7. All seemed good until I put film, shot 2 frames and turned the camera off.
When I turned it back on, LCD never came on, some wheezing sound and the camera turned off.
I figured how to take the film out, but the problem persists.
I appreciate any ideas or reasons why this may be happening, possible fixes.
dutch_km_user Regular Member • Posts: 172
Re: Anyone can help with a Maxxum/Dynax 7 problem?
Did you check the batteries?
 dutch_km_user's gear list:dutch_km_user's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A900 Sony DT 18-70mm F3.5-5.6 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +6 more
neilt3
neilt3 Veteran Member • Posts: 3,008
Well , after 4 months of asking , did you bother to check the batteries ?
It's hard to help you fault find if you can't be bothered replying to your own thread !
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Vegar Beider Regular Member • Posts: 467
Hello User2518922339!
Have you tried without a lens attached or tried with a different lens?
Regards
 Vegar Beider's gear list:Vegar Beider's gear list
Sony RX100 III Sony Alpha NEX-7
OP User2518922339 New Member • Posts: 9
I am sorry. I failed to respond. Thanks for caring.
Batteries are not the problem. It turned out to be the problem with the aperture mechanism.
Unfortunately is an expensive fix probably.
