Good workout lens
Started 10 months ago | User reviews
Howie Dewing
Howie Dewing Junior Member • Posts: 38
Good workout lens
This lens is old enough for a bar mitzvah. It's held up well despite a Version II coming out. It weighs a ton and curiously does not give me a 1.5X crop on my a77 II. I was hoping for it to be the 36-105mm gap between the Sony 16 50mm f/2.8 and the Minolta APO 80-200mm f/2.8 lenses. Oh well. It still delivers incredible photographs and works really well for video with its SSM. Just prepare yourself to have tired arms at the end of the day.
 Howie Dewing's gear list:Howie Dewing's gear list
Sony a77 II Sony a7 II Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) +12 more
Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T*
Zoom lens • Sony/Minolta Alpha • SAL2470Z
Announced: Jan 30, 2008
Howie Dewing's score
4.5
Average community score
4.5
Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony a77 II
Lensmate
Lensmate Veteran Member • Posts: 6,524
Re: Good workout lens
Its a fabulous lens, well worth troubling with the heft!
-Martin P
 Lensmate's gear list:Lensmate's gear list
Sony Cyber-shot DSC-F717 Sony RX100 Sony RX100 VII Sony Alpha DSLR-A100 Sony SLT-A55 +11 more
ajff Contributing Member • Posts: 553
“curiously does not give me a 1.5X crop on my a77 II”
Not really understanding ... why not?
A.J.
Have Fun Taking Pictures!
 ajff's gear list:ajff's gear list
Sony SLT-A77 Sony a77 II Sony 50mm F1.4 Sony DT 11-18mm F4.5-5.6 Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +12 more
Howie Dewing
OP Howie Dewing Junior Member • Posts: 38
Every other full frame lens I've used has yielded an effective 1.5X focal length increase. This one doesn't.
William Curtindale
William Curtindale Veteran Member • Posts: 9,375
I agree the SAL 24-70mm f/2.8 ZA SSM is a wonderful lens. My last usage of that lens was about 1 1/2 years ago for a wedding.
I am 77 years old now which is not so old but my strength is not what it used to be so I sadly parted with my heavy 24-70mm f/2.8 ZA and 16-35mm f/2.8 ZA and several other FF ZA primes (it was emotionally had to do because of their performance and pride in ownership).
I migrated to lighter weight / smaller Sony equipment in effort to keep my photography passion alive.
Enjoy your 24-70mm f/2.8 ZA.
I enjoy content, simplicity and light weight: A6500 and A7C w/Sony + Zeiss + G Glass
 William Curtindale's gear list:William Curtindale's gear list
Sony a7C Sony a6500 Sony 70-200mm F2.8 G Sony 70-400mm F4-5.6 G SSM Sony FE 90mm F2.8 macro +9 more
alanlinde
alanlinde Regular Member • Posts: 467
I suggest you check the coverage. The lens optics can't change and your sensor size is smaller than FF so the field of view captured by the APS sensor is necessarily smaller than on FF.
Alan
Snowfella
Snowfella Senior Member • Posts: 1,303
Crop isn't an effect of the lens used but the sensor it's used on, so there's absolutely no chance that you didn't get the 1.5x crop factor using that lens on an APS-C body!
 Snowfella's gear list:Snowfella's gear list
Sony SLT-A77 Sony a99 II Sony a7R IV Sigma 150-500mm F5-6.3 DG OS HSM Sony FE 70-200 F4 +4 more
BigGG Contributing Member • Posts: 930
I have the Sony 24-70Z1 on my a99 and it works great. but it is heavy
GaryG
 BigGG's gear list:BigGG's gear list
Sony SLT-A77 Sony Alpha a99 Sony a77 II Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH +43 more
Thanks, my point exactly ..
don’t understand original poster’s point of view (🤪)!
A.J.
AndytheHobbit Forum Member • Posts: 83
how does it compare against 16-50/2.8 ?
toughluck Veteran Member • Posts: 3,750
I had both. Across the frame, the 24-70 is as sharp or maybe even sharper than the 16-50 in terms of line pairs per mm.
So your pixels are as sharp as 16-50 but you get more of them.
On a 24 megapixel APS-C vs 24 megapixel FF, given similar sensor performance, the 16-50 could be slightly better because you don't need to stop it down as much to get the same depth of field.
 toughluck's gear list:toughluck's gear list
Sony a99 II Sigma 50mm F1.4 EX DG HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 85mm F1.4 ZA Carl Zeiss Planar T* Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +7 more
garykohs
garykohs Veteran Member • Posts: 5,322
I love mine ...
I have largely switched to E mount but I still love this lens with the LAEA3 adaptor on my A7Riv. I haven't felt the need to have a native E mount lens in this category.
 garykohs's gear list:garykohs's gear list
Konica Minolta Maxxum 7D Sony a9 Sony a7R IV Canon EF 135mm F2L USM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +7 more
QuietOC
QuietOC Veteran Member • Posts: 5,328
Both seem to have fairly high sample variation. I would choose them based on your focal range preference. The 16-50 is an SSM II lens as far as focus tracking.
 QuietOC's gear list:QuietOC's gear list
Pentax Q7 Sony a7R IV NEX-5T Sony a77 II Sony DT 16-105mm F3.5-5.6 +92 more
This. Mine is tack sharp. I wanted to replace it with the SSM II version, but a cursory comparison showed that the II that I bought was obviously inferior to the one I already owned.
SSM II is better, but especially for tele lenses. The standard focal lengths don't benefit as much because you're not really using them for tracking.
