Two DSLR with a Kodak CCD sensor
Started 11 months ago | Discussions
Mescalamba Contributing Member • Posts: 902
Re: Two DSLR with a Kodak CCD sensor
SQLGuy wrote:
Mescalamba wrote:
Mirror shock probably. A900 had huge pentaprism and equally huge mirror. It slapped quite a bit. With delay I cant say I noticed any shutter shock. Just needs mirror lock up.
Not only camera with this issue, nearly everything with big mirror needs it, down to physics and even with serious damping not really avoidable. Mirrorless does have advantage there.
It's actually a very different mirror in the A900 than most anything else. It folds up more than flips up. As I understand a different mechanism was needed to accommodate the 100% viewfinder.
So, at what shutter speeds and focal lengths were you having issues? For mirror shock, I'm surprised that IBIS didn't help...
Im not the guy which wrote about it, but it gave some issues with long focal lengths and slower speeds (200mm, 1/30th). Usually its recommended to disable IBIS when you are using tripod. My old K7D doesnt like stabilization and tripod much so I always assumed its not much different. TBH dont think I ever tried that, maybe I should have.
SQLGuy
SQLGuy Forum Pro • Posts: 11,330
Here are two at 200mm and 1/30th. Supported, but not on a tripod. IBIS on.
They're soft-ish, but, at F25, I would expect that.
2 sec self timer (mirror lockup)
Standard drive mode
A7R2 with SEL2470Z and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Canon EOS-1D Canon EOS 5D Fujifilm FinePix S5 Pro +34 more
da7329 Contributing Member • Posts: 920
Have you ever compared the Kodak slr/n,c with the P880?  I would be interested in the colors between the to.  Big difference in sensor size but they were released within a year or to of each other. Thanks
DA
Maoby
OP Maoby Veteran Member • Posts: 4,289
No sorry, I don't own any of these cameras.
If you are interested, you can see all of my comparisons her : https://www.flickr.com/photos/maoby/albums/page2
 Maoby's gear list:Maoby's gear list
Olympus E-10 Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II N Canon EOS-1Ds +79 more
