Can the M200 do focus stacking?
Started Feb 11, 2021 | Questions
roedj Forum Member • Posts: 61
I've looked through the M200 manual and I can't find where it talks about the M200 focus stacking - combining several stills taken at a different focus point - into one image. I realize Helicon can do it externally but can the M200 do it internally?
Dan
IWBF
IWBF Regular Member • Posts: 360
Re: Can the M200 do focus stacking?
Dan
No, unfortunately not. Not even bracketing.
drsnoopy Senior Member • Posts: 1,216
You can focus stack with any EOS camera by using the Camera Connect phone app, or EOS Utility app on your laptop (tethered via USB).
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
IWBF
I use EOS Utility which is a phantastic software. However, I have to do the stacking manually. If you could elaborate how to do automatic stacking I would be very grateful.
Edit: Not every EOS camera can be tethered. The M200 can, the M100 not.
You have me there, I haven't tried it, only read about it. My understanding is that all you need is to tether the camera and use an autofocus lens. I intend to try it with my M5 but I also have other non-M bodies (80D, 5D4, R) and several lenses to try it. Here's an article describing how to do it, seems fairly straightforward:
https://zerenesystems.com/cms/stacker/docs/tutorials/usingcanoneosutility
IWBF
Thanks. Unfortunately the process described in your link is how I do it. It is simple and easy to bracket 10-20 images. But very time consuming and boring for more.
Anyway, I am glad at least it can be done in a way.
My guess is that you can hope for automatic bracketing on the R.
IWBF
Automatic bracketing with phone app
I found an android app that can do automatic focus bracketing with an M200. You need an OTG cable to tether the camera. It can do up to 100 images with predefined steps.
The app is called "Camera Connect and Control" and has a free 3 day fully functional trial version.
Will do some more testing now.
