Pinhole camera: cheapest place for Polaroid film?
Started Feb 11, 2021 | Questions
chaimav
chaimav Senior Member • Posts: 1,577
My daughter is making a pinhole camera for her school science fair and based on her research, she decided on Polaroid film. (Its too much effort to start trying to develop film ourselves). Does anyone know an affordable source to buy it? I can't seem to find it for less than $15 for an 8 pack.
 chaimav's gear list:chaimav's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Pinhole obscura alternative
That can work, although it's a pain to handle the Polaroid film because you need it kept in the dark and then processed in the dark. Also, to demo it indoors, you'll get a really long exposure because film speed for Polaroids isn't fast and pinholes don't pass much light.
The other possibility is to make a pinhole obscura.
Let the pinhole project onto a sheet that you can view (or photograph).
The following was an obscura (with a lens) that I built for an open house in my lab. We used it to demo single-lens anaglyph capture, but the basic box would work for her too with a pinhole rather than a lens up front:
Front
Basically, build your pinhole camera, but place something like tracing paper where the film would go and use a box to shade that for rear viewing -- now you've got an obscura. To capture an image from it, simply use a digital camera to photograph the tracing paper.
I described my much classier digital pinhole obscura here back in 2016: https://www.dpreview.com/forums/thread/3996328 . That design uses a 3D-printed structure for the pinhole obscura. The 3D-printed part designs are posted at https://www.thingiverse.com/thing:1515060 , which also has photos of the unit and images captured with it.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
chaimav
OP chaimav Senior Member • Posts: 1,577
Re: Pinhole obscura alternative
We have the handling of the film part down. In a dark room one person takes a film sheet out and gives it to someone else to load the camera. They then seal the rest of the package with tape.
The hardest part seems to be the rolling of the chemicals for development. The issue is securing the image in place. We have tried multiple methods and the one that worked the best was taping the image from the back and rolling it with a rolling pin.
Bowl of oranges.
Gato Amarillo Veteran Member • Posts: 9,340
Bowl of oranges.
Pretty cool -- seems like you're on a good track.
As to Polaroid prices, I don't think you'll do much better than what you already found.
Gato
Johannes Zander Regular Member • Posts: 467
Bowl of oranges.
What about passing it through a laminator with the heat turned off?
 Johannes Zander's gear list:Johannes Zander's gear list
Nikon 1 V1 Nikon D4S Nikon Z6 II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 24mm f/1.4G ED +21 more
