Exchanging my 23 f2 + 35 f1.4 to 16-55 f2.8, good or bad idea?
Started Feb 8, 2021 | Discussions
jidccruz Regular Member • Posts: 119
I saw an ad selling his 16-55mm primarily to buy primes. He's willing to exchange it with my 23 f2 and 35 f1.4. Do you think it's a good idea? I love both lenses but sometimes it's hassle to decide which lens to use. I want the quality of the 35 f1.4 almost all the time but sometimes it's limiting so I'm using the 23 f2.
I'm using them with an X-T30 so I love the compactness. I know 16-55mm is a beast and I'll adjust with its size and weight.
I also have an X100S, if that will help.
 jidccruz's gear list:jidccruz's gear list
Fujifilm X70 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm 16-55mm F2.8R LM WR XF 90mm
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100S
biza43 Forum Pro • Posts: 15,074
Re: Exchanging my 23 f2 + 35 f1.4 to 16-55 f2.8, good or bad idea?
Do you need f/2 or f/1.4?
Good or bad, only you can decide. Often, the best option is to have the flexibility of the focal range of the zoom, complemented by the flexibility of the fast aperture of a prime.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
MartinNorfolk
MartinNorfolk Regular Member • Posts: 483
Only you can really answer that question. Sorry.
thedanj
thedanj Contributing Member • Posts: 505
What do you primarily shoot? What environments? How important is size to you? How often do you typically shoot the lenses you have wide open? I personally would never make this trade, but then I prioritize a small kit and the ability to shoot with wide apertures. If you find that size is not that much of an issue for you and that you typically stop down those lenses, particularly the 35, then it might be worth it to you to have a single lens that can cover that entire focal range.
 thedanj's gear list:thedanj's gear list
Fujifilm X-T20 Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R
OP jidccruz Regular Member • Posts: 119
I'm a hobbyist which loves to capture family moments primarily. When outside, I often stop down to 2.8 or 4 for the sharpness.
DarnGoodPhotos Forum Pro • Posts: 11,881
Its a good idea if you want a zoom more than you want f2 or f2.4. And besides, you can always buy one of those lenses again should you want one in the future.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
fujiian
fujiian Contributing Member • Posts: 718
With this use case, I think you'll like the 16-55.  It's definitely my 'around people' lens, because it can capture very sharp photos, from a variety of FLs, without changing lenses.
However, I still keep my 35/1.4 around for low light and its compact size.  Tough to say you wouldn't miss either lens you let go.
 fujiian's gear list:fujiian's gear list
Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm 50-230mm II +4 more
stephenseriously
stephenseriously Regular Member • Posts: 103
if 35mm feels too tight occasionally, have you considered grabbing an inexpensive backup body to carry with the 23mm or maybe a secondhand 18mm attached? that'd save you time changing lenses, and you'd get to keep the fast aperture and save on size and weight. the X-E3 both new and gently used is pretty reasonably priced for now, not sure if that'll get better or worse when it's discontinued in favor of the X-E4. I don't know about you, but any time I find myself pining for a zoom lens, it's usually because I want one or both of the focal lengths at the extreme ends or the middle.
 stephenseriously's gear list:stephenseriously's gear list
Fujifilm X100V Fujifilm X-T30 Fujifilm XF 18mm F2 R Fujifilm XF 23mm F1.4 R 7artisans 35mm F1.2 +3 more
Flying Fijian Senior Member • Posts: 1,623
16-55 obviously gives you more range than just your 23 & 35 so it's definitely worth thinking about. You could try it & then later add back the 35 1.4 if you miss it (you probably will).
Or if you're happy with those 2 lenses you could just add a cheapish second body like an xe3 & sell the x100s? So you have 2 bodies & 2 lenses...ie no lens swapping...or X100V paired with your xt30 & 35 1.4...sell the rest. You could add a 56mm later on too if you like.
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
Brian Kimball
Brian Kimball Contributing Member • Posts: 756
In terms of handling, the 16-55 is affectionately called "The Brick" for a reason. It's going to completely change what it's like to hold your X-T30 and go shooting with it (vs the 23/2 or the 35/1.4).
Whether you'll like the change only you can decide.
http://camerasize.com/compact/ is a useful tool:
EOS GUY
EOS GUY Senior Member • Posts: 5,342
Financially it;s slightly in your favour so on that note I'd say nothing to worry about.
The 23mm F2 has excellent quality so I have to assume you mean the 35mm has more bokeh when you say quality? If it is that then obviously you will lose that with the 16-55
I haven't had the 35mm f1.4 so I acknowledge you may mean it does have some excellent IQ character even over the 23mm f2 however.
I have an X-T2 and tried out the 16-55 f2.8 and honestly was put off by the size and weight. And I used to carry a Nikon D5300 with Sigma 17-50mm F2.8 OS DC HSM
On an X-T30  - if people (and they exist) find it too front heavy on an X-T model, well on an X-T30...  but neither camp are right or wrong it's subjective to each person
Lol that's tiny even compared to an X-T30. I owned and loved an X-100 T for 2 years.
But this is MY subjective experience and you will find as many people saying it's fine on an X-T2 for sure and some even on an X-T10/20/30.
So only way is try before you buy.... Or buy and try and then send back (not to an ebay non business seller though, that's real harsh, I mean a big retailer under your 14 day return rights - here in UK)  I only say that as I'm assuming like us in the UK under covid restrictions you may not be able to enter a brick and mortar store and try one out
As for image quality, I don't think you'll lose ANY except of course a stop of light compared to the 23mm F2 and two stops compared to the 35mm F1.4. And of course less BOKEH!  Though as I wrote above maybe the 35mm f1.4 is really special but I cant comment on that
So in my subjective opinion it boils down to
1. Size and weight (only you can tell by trying)
2. Bokeh (how much do you like bokeh?)
3. Low light. Do you need faster than F2,8?
4.  How special is the 35mm at f2.8 and narrower over the 16-55 at 35mm...?
My Instagram - https://www.instagram.com/photonicstreetdreams/
The earth laughs in flowers.
-Ralph Waldo Emmerson
Before you say (or post in our context) = THINK.
Is what you're going to say - True. Helpful. Important (or Inspiring.) Necessary. Kind.
I have G.A.S, - gear avoidance syndrome.
 EOS GUY's gear list:EOS GUY's gear list
Panasonic LX100 Canon EOS Rebel SL1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Canon EF-S 24mm F2.8 STM +6 more
