Re: Improve X100 competitor : Ricoh GR
DarnGoodPhotos wrote:
forest dream wrote:
Agree. Most of mid-range smartphone (e.g. iPhone SE 2020 $399) main rear camera has OIS.
Since smaller APS-C Ricoh GR III has IBIS, no reason larger Fujiflm X100V can't doing. Nobody request IBIS must > 5 stops.
I don't know why you brought up stabilization in phones. Those sensors are tiny and their small lenses are mediocre. Furthermore, no one expects optical excellence from a phone.
The GR, however, is an appropriate example of stabilization.
May be X100 series only will aggressive improve lot if next Ricoh GR :
- Built-in pop-up EVF/OVF (like Sony RX100 series, but can switch via replace EVF/OVF part)
- Tilting screen (like Sony RX100 series).
- WR include lens.
- Change to 20mm (30mm equivalent) F2 lens.
- Optional flash attach on side of camera (like Contax T optional side flash).
- Better touch screen menu like BMPCC 4K.
- Increase physical button via redesign PASM dial into D-Pad + larger PASM (just like existing rear bottom dials).
- Improve battery life via dual layers screen (B&W LCD screen/color AMOLED which used in TicWatch Pro smartwatch).
Thats a whole lot of what-ifs you think the next GR will get.
1 - Don’t want because no OVF.
Has popup OVF but not hybrid.
2 - I’m fine with the XE4’s screen but really I’d rather the X-T3’s screen.
For keep Ricoh GR true pocketable sizesize, 1 way tilting screen.
3 - Don’t want WR if the lens isn’t internally focusing, which is what the X100V with filter is.
4 - 20mm isn’t all that different from 23mm.
For keep Ricoh GR true pocketable size, can't use internal focus lens.
5 - I’d rather an X-E2 style flash instead of one that primarily illuminates one side of your subject.
6 - A better screen is always good
7 - I don’t want a PASM dial
E-Ink top-plate + a unmarked dial (has D-pad on top of dial for quick switch dial function) may be better for keep Ricoh GR pocketable size.
8 - I spend so little time in the menus that I doubt it would noticeably improve battery life for me.
Improve battery when only use popup OVF + LCD screen for menu or basic info.
