A7c and shutter speed
MDGolfer Regular Member • Posts: 204
Has anyone felt limited shooting portraits wide open with f1.4 lenses on A7C?
On a sunny day, is the 1/4000 shutter speed fast enough?
Sony a7
QuietOC
QuietOC Veteran Member • Posts: 4,728
Re: A7c and shutter speed
How much do you want to blow out highlights?
I was getting overexposure at ISO 100 with the Rokinon 35mm F1.8 at 1/8,000 s yesterday under overcast sky shooting down on snow using highlight metering on my A7III. I had to drop down to f/3.2 to avoid overexposure. The Rokinon supposedly has fairly poor transmission too.
I also had a lot of trouble using a Maxxum 70 with 1/2,000 s shutter with any prime. It is too bad 1/12,000 mechanical shutters like the Alpha 9 and 9xi film bodies are not available.
You can use ND filters.
 QuietOC's gear list:QuietOC's gear list
Pentax Q7 Sony a7R IV NEX-5T Sony a7R II Sony a77 II +93 more
(unknown member) Veteran Member • Posts: 5,193
Nope .
The sunny 16 rules says f/16 ISO100 1/100
Which is the same lightness as f/1.4 ISO100 1/12800
So 1/4000 is not fast enough if you want to use the widest aperture, unless you use a ND filter.
WaseemH Forum Member • Posts: 87
Thanks for your replies.
 WaseemH's gear list:WaseemH's gear list
Sony a7C Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sigma 85mm F1.4 DG GN
William Curtindale
William Curtindale Veteran Member • Posts: 9,151
Nope .
I always have an ND 8 filter in my bag if needed. I would probably be using a 3' x 6' light defuser.
When it comes to environmental portraits I always arrange my subject with their back to the sun or setup in the shade (bright sun causes the subject to squint). Actually I like to arrange the subject so the sun will cause a back lit rim around their hair. I will need to wait for nice weather to do outside portraits with my A7C. I would not be shooting at f/1.4 but could be at f/1.8 or f/2.8 with my 85mm f/1.8 or 90mm f/2.8 macro G.
I understand the point the OP is making but I usually don't shoot portraits wide open (so I don't expect an issue for me).
I enjoy content, simplicity and light weight: A6000, A6300, A6500 w/Sony + Zeiss + G Glass
 William Curtindale's gear list:William Curtindale's gear list
Sony a6500 Sony a7C Sony a6000 Sony a6300 Sony E 16-55mm F2.8 G +16 more
jb12 Regular Member • Posts: 233
That and the lack of a full mechanical shutter are the reasons I did not buy the a7c. Hope the next version is more photography friendly.
unhappymeal Senior Member • Posts: 1,021
Nope .
I can't wait until Olympus'  and Ricoh's LiveND gets picked up by other systems. It's 2021, there's no need to still be carrying ND filters when you can stack images in-camera.
 unhappymeal's gear list:unhappymeal's gear list
Ricoh GR III Panasonic Lumix DMC-GM5 Olympus E-M1 III Panasonic Lumix DMC-GF2 Sony a7C +20 more
