Buying a used GX7
Started Feb 4, 2021 | Discussions
tombarrance New Member • Posts: 23
Buying a used GX7
I need a small carry-anywhere MFT body, mainly for stills and occasionally as a second body for 1080p video (I already have a G80 as my main video camera). I'll mainly be using it fully manual, occasionally aperture priority. Essentials are good manual handling and a tilting screen.
A 'nearly new' used GX7 looks like the best option, is there any reason I shouldn't get it? Anything I need to look out for?
Panasonic Lumix DMC-GX7
Henry Richardson Forum Pro • Posts: 21,959
GX7 or GX7II or GX7III?
I assume you mean the original GX7, right? How much for the used one you are looking at?
I paid US$269 for a very nice used GX7II in Tokyo in January 2020. Here is my user review:
https://www.dpreview.com/forums/post/63703723
I just checked and the same shop in Tokyo is selling used GX7II bodies for about US$335 now. Price in yen has increased and at the same time the U.S. dollar/yen exchange rate makes the dollar price a bit higher too.
Henry Richardson
http://www.bakubo.com
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
Re: Buying a used GX7
Where are you.  I'm in the UK and I have a GX7 that I will let go for a nominal fee.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
OP tombarrance New Member • Posts: 23
I am in the UK - how much do you want for it?
Re: GX7 or GX7II or GX7III?
I was looking at MPB, their best used GX7s are £189 ($256). The GX80 (UK version of GX7 II) is £269 (£365). I like the tilting viewfinder on the older version.
Keit ll Veteran Member • Posts: 5,172
The 16 MP GX-7 has taken on a new lease of life if used in conjunction with Topaz Denoise/ Sharpen products or similar.  It is a good looking camera with a nice grip.
Using the electronic shutter avoids any possible issues due to shutter shake which can occur at certain speeds with the mechanical shutter.
Trevor Carpenter
PMd you
AdamT
AdamT Forum Pro • Posts: 62,285
Two Issues I have found
The Orig GX7 has TWO issues that I`ve found (had one for years)
1:- Shutter shock - its worse than the GX8 , affects the 14-140 more than anything but does with other lenses too - I used mine in E-Shutter all the time as a consequence, , yeah there you get wobbly slow scan issues but didn`t affect what I was shooting much
2:- the sensor unit is prone to dust ingress in the stack which can`t be removed, same goes for the GM1, GM5 and I believe the G7 too . this basically scraps the camera if it gets bad enough to drive you nuts removing the splodges , I had the sensor stack on mine replaced under warranty , it killed my GM5 (got loads in the end ) and one of my GM1s and the replcement sensors weren`t sealed any better
Saying that I did actually really like my GX7, I never gelled with the GX80 or GX9 which is weird , found them fiddly , prob the lack of grip and the closeness of the rear buttons to the edge, actually found the EVF optics in the GX7 better than the GX80
The GX7`s IBIS isn`t up to much but due to the decent grip , it`s no less shaky than the GX80 despite the GX80s supposedly better IBIS (I found the GX80 / GX9 IBIS pretty lame at least for stills - the G9 and EM1-II are Gimbals in comparison )
saying that I`d still recommend a cheap used GX80 - the sensor stack is sealed properly and has a better scan speed, the shutter is Shock free and the IBIS although lame for stills is 5 Axis so may benefit Video more .. The total King of the Pan RF line is the GX8 of course and these can be had for very decent money in shops used - age related shortcomings of course but its the only "semi Pro" level RF style M43 cam panasonic ever made or are likely to make  and you get that fantastic 20MP sensor and superb EVF
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
Re: Two Issues I have found
Thanks, that's helpful
bs1946
bs1946 Veteran Member • Posts: 7,779
One issue with buying a GX7 II, aka GX80 and GX85, is that is that the GX7 II, is only sold in Japan and it only has Japanese menus and screens that Panasonic locked down so you cannot change the language. The GX7III may be the same, so investigate carefully unless you read Japanese.
As for the original GX7, one flaw with the camera is there is little space on the back and the command dial was too easy to accidentally turn and change a key setting without even realizing it.
Bill S.
www.flickr.com/photos/wrs1946
instagram.com@billschaffel
“Sharpness is a bourgeois concept”
– Henri Cartier-Bresson -
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Bad info
That is not true about the GX7II and GX7III in Japan. And, of course, also not true about the GX85/GX80 in other countries either. And why would the OP even think about coming to Japan during a pandemic to buy a used GX7II? The entry restrictions and rules are always changing, but even someone who wanted to do that would probably find that it is pretty difficult. Much easier to just buy a GX85/GX80 locally.
Henry Richardson
eilivk Senior Member • Posts: 2,580
Bought it last year ago, almost like new ($150). For the tilting EVF, not for the type of screen tilt, and for the IS. Found no fault, very pleasant to use, clearly better than my G3. The main small camera in strong light, when NX 20 and 30 are too large.
 eilivk's gear list:eilivk's gear list
Canon PowerShot G10 Ricoh GR Digital Fujifilm FinePix F200EXR Ricoh CX4 Sony RX1 +10 more
kcdogger Veteran Member • Posts: 4,356
Great camera.  I'd look for a good one (by description and  maybe shutter count)  and buy it and be happy.  It is still a geat camera.  Yes, I have one.  Go for it!
Peace.
John
 kcdogger's gear list:kcdogger's gear list
Olympus Stylus 1 Panasonic ZS100 Sony RX100 VA Panasonic Lumix DC-ZS80 Olympus TG-6 +37 more
brentbrent Veteran Member • Posts: 5,766
I have not experienced any shutter shock issues with the GX7, nor any dust in the sensor stack. Nor do I think those are widely reported issues. I still have mine, great little camera.
The GX85 certainly has some improvements over the GX7, but it also has a number of downgrades to meet a lower price point. Here's a list of most of them: https://www.dpreview.com/forums/post/59716801 One error on the list: the flash on the GX85 can be tilted up.  One omission on the list: much better grip on the GX7.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
richj20 Forum Pro • Posts: 10,181
Consider a thumb grip
It may make carrying this wonderful camera much easier.
Fotodiox thumb grip mounts onto the hot shoe; does not interfere with opening the built-in flash.
- Richard
eques Veteran Member • Posts: 4,115
look out for controlwheels
the thumbwheel of my GX7 had to be replaced abd now it starts malfunctioning again. Same problem with a second GX7.
This however seems to be a common problem for most Panasonic m43 cameras.
So make sure you can return it.
Otherwise a great camera, with excellent grip.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
