Still one of the best
Started Feb 3, 2021 | User reviews
R Saum
R Saum Regular Member • Posts: 322
This is still one of the fastest focusing Lenses available. It is still one of the sharpest optics available in the Canon line. Yes the newer 400, and 300, and 200 might be faster, and have hair of an advantage in image quality, but you better have a lot of time, and some very good measuring equipment to see it. I use it on a 1DX and it is the fastest lens I own, I also used it on the old 10D and this lens makes that cameras AF unbelievable. If your not using this lens to compete for jobs, it is definitely the better option than dumping 4 times what these can be bought for and you will never see the difference in the final product! I will work with a little more weight for the savings, and the newer IS on the IS II does little for you when these lenses are used on tripods or monopods most of the time! If you have a chance to pick up a clean copy of this lens don't hesitate, you won't believe the capability and the images it will produce!
 R Saum's gear list:R Saum's gear list
Canon G7 X II Canon EOS 10D Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 70D +11 more
Canon EF 300mm f/2.8L IS USM
Telephoto prime lens • Canon EF • 2531A002
R Saum's score
5.0
Average community score
4.8
BlueRay2 Forum Pro • Posts: 14,816
Re: Still one of the best
i have the canon 300 f2.8 II and i find it an amazing piece of engineering. it lighter than the model you have described, the optics have been rearranged than your model so the weight is distributed more towards the rear, which makes it perfectly balanced. i visited san francisco zoo a few years ago and held my rev.II in my hand all day, hardly felt the wight that much.
now i use my lens with TC 2.0x III mainly for birding, all the time and they work together very nice together, hardly any hit in IQ. but as you said, for someone who has smaller budget, the rev.1 would be perfect, still the same quality lens!
Absence of evidence is not evidence of absence!
R Saum
OP R Saum Regular Member • Posts: 322
I agree, yes I just wanted to put an updated review to to this lens, to assure those wondering why this lens is so cheap today, and is it really worth it, that there is no way they would be disappointed in performance. Like you said it sure would be nice to have the lighter and better IS, slightly better balance but they are not giving up performance using this older 300mm F2.8. On a good gimble head the balance is always perfect. So if the primary use is on a tripod, their is little advantage once set up and properly balanced.
I like you have used the newer version on loan in my case, and on my budget, I am very happy this old lens is available, but if this was a lens to support my family and used frequently to provide my income, I agree the newer lens is a worthy value.
One thing I failed to mention is the one gamble one takes buying this lens, is Canon no longer offers parts for repair on this lens. But the fact that it so tank like built, and with the highest quality components, most failures will most like be user inflicted. But they have proven to take a lot of abuse that most amateur's seldom introduce to their equipment,,,, just a heads up.
hockeyshooter
hockeyshooter Senior Member • Posts: 1,442
Thanks for posting this. Before it was stolen I used a pre-IS 300/2.8 for sports and found it was very sharp. Am now looking at getting a replacement but even used, the MkII is around £4k - whereas I can get a decent MkI for less than half that. I think that if a MkI is  an optical improvement over the old lens, I'd probably be happy with it.
Chris.
Freelance sports photography
http://www.hockeyphotos.com/
 hockeyshooter's gear list:hockeyshooter's gear list
Canon EF 70-200mm f/2.8L USM Canon EF 300mm f/2.8L IS II USM Canon EF 100-400mm F4.5-5.6L IS II
Chris.
if you can find a rev.1 at a reasonable price, i'd grab it. a pound or so heavier is not going to be a deal breaker, IMO. unless you are 75 or over, i wouldn't worry about the weight i can assure you you are going to find this lens stunningly fun to use.
good luck.
Nature is under no obligation to make sense to us!!!
hockeyshooter
Got one at a pretty good price - almost the same as my pre-IS one did back in 2000 - and its superb. No problems hand holding it for the ice hockey and the sharpness is outstanding.
Chris.
bigshledge Contributing Member • Posts: 596
I had a lend of one of these back in 2009. Blew me away on how ridiculously sharp it was. Also destroyed my back, as I hand held it!
I still lust for that lens to this day.
 bigshledge's gear list:bigshledge's gear list
Canon EOS R6 Canon EF 100mm f/2.8 Macro USM Canon EF 8-15mm f/4L Fisheye USM Canon EF 100-400mm F4.5-5.6L IS II Canon RF 28-70mm F2L USM +1 more
