Identical Cameras But Images Aligned Differently - Why?
Started Feb 2, 2021 | Questions
PW-Wis
PW-Wis New Member • Posts: 3
For the past year I have been experimenting with stereo photography. I have two Canon Elph 180 cameras mounted on a flat stick side-by-side. I crop the images, put them side-by-side and email them to my phone. Then I use a vintage stereoscope viewer to view them. It's a great way to capture views that don't translate well to 2D, like snow piles.
But yesterday I noticed that there was a mismatch at the top/bottom of my photos. I thought it was my stick, but it was straight. Then I looked at past photos from two identical Lumix ZS-19 cameras (with flatter bottoms) and they had the same issue. Even placing them side-by-side on the kitchen counter, I could see a vertical difference on the screens.
I can edit the difference out of my photos in the future, but the question is: why is the vertical alignment off on identical cameras? Does the lens sag over time? These are zoom cameras so the lens extends from the camera (though I shoot at the shortest lens position to keep the views identical).
And as you can see below, the difference is significant. For being such precision devices, I did not expect this to be possible.
Snippet from upper left corner of my photos. Outline shows the difference in the vertical alignment.
Canon Elph 180. The lens doesn't protrude far when turned on.
Canon PowerShot ELPH 180
CarlStereo New Member • Posts: 2
Re: Identical Cameras But Images Aligned Differently - Why?
This issue is Quite common on cameras with optical zoom lens according to my experience.
However, even on fixed lens cameras. Issues are still there.
I own 4 identical Nikon key170 action cameras
Not any 2 of them are perfectly vertical aligned.
Worth to note that Nikon key170 has fixed focus lens without any moving parts or any in-body optical image stabilization (same as gopro).
I also have 2 Sony zv1, same vertical aligning issue even when i disabled in-body image stabilization.
So in my opinion. Consumer cameras are not designed with 3d-in-mind.
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
I don't mean to sound trite, but the reason is the cameras are NOT identical.
There is a plethora of reasons why.  The prior post explains common reasons.
If you want identical, use a single camera in cha-cha mode.
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
PW-Wis
OP PW-Wis New Member • Posts: 3
Thanks for your reply. Since you have fixed-lens cameras with differing alignments, that eliminates my zoom-lens theory. And saves me from wasting time and money on exploring that next.
I lopped off the non-aligned parts of the photos and got a good result. The only true fix would be to have some sort of adjustment made to my stick. I don't have woodworking skills, so digital adjustment will have to do.
Brian F Flint
Brian F Flint Regular Member • Posts: 184
I guess you are using the thread under the camera to mount the two cameras on a stick.
I have done this myself with a number of different pairs of 'identical' cameras.
The miss-alignment you have with the verticals is very common problem. It is basically because the base of the camera ( where the thread is ) is not completely flat and identical on the two cameras. One solution I use is to view the two LCDs side by side and make a note of the mismatch and then add a piece of masking tape just under the camera on one side of the place where the thread is ( so that the camera tilts very slightly forward of backwards ). Keep doing this until the images on the two LCDs are showing correct vertical alignment.
Other issues are that the zoom on each camera is not identical for the same setting. Hence one image is slightly larger than the other. This may be only 1 or 2% . It is due to normal manufacturing tolerances.
I would recommend turning off any image stabilisation as this can cause issues.
For best results put the left and right images into an app called StereoPhotoMaker which is run on a PC and this will allow adjustment so that the alignment is  virtually perfect. This software is free of charge.
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
Artak Hambarian
Artak Hambarian Junior Member • Posts: 40
In addition to Brian Flint's perfect advice, I would also suggest using two simplest heads and easily achieve alignment by adjusting them by looking at the LCD screens.
Dr. Artak Hambarian,
College of Engineering
American University of Armenia (AUA)
 Artak Hambarian's gear list:Artak Hambarian's gear list
Fujifilm FinePix Real 3D W3 Nikon Coolpix P500 Nikon Coolpix P330 Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +19 more
PW-Wis
Thanks for the software info. Nifty tool that may save me a lot of time. I had to resize my images first because my snow was losing detail but that might just be due to snow being too much of one color. Pretty cool how it lets me choose my output file size.
And you may be right about the zoom factor being slightly different. I placed two cameras side-by-side on my window and there was a horizontal difference in the LCD display.
