Minolta A9 with MC glass question
Started Feb 2, 2021 | Discussions
Kremdela New Member • Posts: 2
Hello, I have a issue I can’t seem to figure out, I have my Minolta A9 and I got an adapter from fotodiox that allows MC/MD glass to attach to A mount bodies, when I attach them and I go to take a picture the shutter button doesnt do anything, wont let me take a picture, I made sure it was on MF, I tried new batteries just incase, but its definitely something with the adapter n MC lens, I re put my AF 50mm 1.7 on it and it works just fine, I tried the adapter and MC glass on my Minolta 5D and it works perfectly fine, so its just the A9 with the issue, any guesses what it could be?
Sony a9
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Minolta A9 with MC glass question
Welcome to the forum .
I assume it works fine with an A mount lens ?
Have you got the manual ?
https://www.butkus.org/chinon/minolta/minolta_maxxum_9/minolta_maxxum_9.htm
Check out the custom functions .
"CF 16" needs to be set to "2" .
"Release without lens " needs to be set to "on" .
By default it's set to "off" .
The reason is if you've not got a lens on your camera and it was switched on , if you caught the shutter release button it would fire  and take a blank shot .
If you put the camera back in your bag with it still switched on , you could end up with a fully exposed roll of film with nothing on , so a bit if care is needed .
When you finish shooting , apart from switching your camera off , it wouldn't harm to reset the camera to auto-focus .
That way the camera won't fire by mistake .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
OP Kremdela New Member • Posts: 2
Thank you! Happy to be here, well thank you very much for that info, I never knew about the custom functions, I will try it when I get home from work and see if I can get it to shoot with a MC lens
neilt3
It's well worth setting all the custom functions up how you like the camera .
Once done you leave it as it is .
If the cameras new to you , have a good read of the manual I linked to .
The Maxxum 9 , Dynax 9 and alpha 9 are all the same camera , just different names in different parts of the world .
Typically any adapter that has glass in it ( like the SR to A that you have ) degrades the image .
Depending on what your using the images for , this might not be noticeable .
Enjoy you camera , and share some images with it if you can .
