Coming back up to the boat at the end of a dive
Started Feb 1, 2021 | Discussions
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Nothing special here.  I'm bored with the lack of pictures here since all the lockdowns, so I'll just post some of my own.
This may help remind us of what we've been missing.
After my safety stop, I ascend to the Henry Morgan, a dive boat out of Oak Ridge, Roatan
The top of my 230mm dome port begins to break surface.
Hey, an over-under!   (While fascinating, I can't seem to do them myself due to the 30 pound camera weight).
I'm actually shocked that the boat is in focus somehow.   Captain Cudy awaits my arrival.  The divemast is putting his gear away, and I'm the only other diver on the boat.
How about somebody else putting up their sequence of shots of something underwater?
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
kelpdiver Veteran Member • Posts: 5,564
Re: Coming back up to the boat at the end of a dive
the bigger the dome, the easier to get focus.   And since you paid the $$$ for the big glass dome, the less likely to have water droplets getting in the way.
I'm going to have to face these trade off questions (dollars and transport concerns) as I shift from a GH4 to an R5 this year.
PHXAZCRAIG
OP PHXAZCRAIG Forum Pro • Posts: 19,651
Yes, and now I just have to learn how to fin so furiously that I lift the 30 pound rig halfway out of the water, aim, focus and get the shot.
At this point, it's more like a failed dolphin jump a bit.  I sort of heave it up pressing the focus lever and hoping for the best in the half second I can hold it out of the water.
www.cjcphoto.net
even with the smaller rigs its a tough thing.   I think you're going to have to submerge yourself with an inflated bc, and just aim semi blind.   repeat a bunch of times.
or being out the floaty device.   I think we've talked about it before - foam options can work, but only if the boat tosses it to you.   Something inflatable on demand could function.  But most of this is a lot of effort unless you're going to do a lot of it.
G7XII compact, with mini dome port
PHXAZCRAIG
To be honest, it's enough effort that it needs to be the purpose of the dive.   I've mostly been trying something here or there at the end of the dive when we get back to the boat.  (Partly because at the beginning of the dive, I don't have the camera ready until I get to the bottom, and partly because the best over/under sites aren't always near the boat).
When I got to Roatan, I get there around 3-4pm in the afternoon usually, and just have time for a checkout dive off the shore.   One year I thought I should stay in the shallow area for a while and practice over/unders in 4-5 feet of water where I could simply stand and hold the camera where I needed to as long as I needed to get the focus right, point the strobes, test exposures, etc.
Turned out even that was too hard!   My standing didn't work so well in fins on big slippery rocks, and it was starting to get dark so I couldn't really see what I was doing above water or below.   From that experience, I think some sort of float is called for here.  I've now seen ads for some.     I'd like something akin to a geared central column on a tripod where I could fine-tune the height of the dome easily.
www.cjcphoto.net
