R6 AF problem: camera or user error - how to avoid?
Feb 1, 2021
Hi everyone,
recently, I shot a few images with my R6 and the RF70-200/F2.8, and I noticed that although the autofocus works pretty well in most situations, sometimes the focus point is not where I put the focus-box on.
Here are three examples. These are screenshots from DPP4 (50% Zoom), which show the focus area as a red rectangle. But as you can clearly see, the actual focused area is behind or in front of the person/red rectangle.
AF problem, F2.8, 1/5000s, ISO100, 200mm, 50% crop
AF problem, F2.8, 1/4000s, ISO100, 200mm, 50% crop
AF problem, F2.8, 1/5000s, ISO100, 163mm, 50% crop
Hopefully you can help me figure out what was going on there. Maybe I did something wrong and can improve my skills.
It was a backlight-scene, that's why the person is pretty dark. Maybe that was causing the focus-problem, but I guess there should be enough contrast on the person's silhouette to get correct focus. At that time the lens hood was not yet mounted. Would that make a difference for the AF?
Some more details: I used Spot AF and Servo AF (back-button focusing). I was panning slowly from left to right and made 5-6 shots (all having misplaced focus). IS enabled. IS mode 1, although IS mode 2 would have probably been better in that case.
I cannot remember whether the focus was breathing at that moment or not. That would be a possible explanation. But I guess it was not breathing.
Here is another, a little older, example:
AF problem, F4, 1/1000s, ISO100, 200m, 100% crop
As you might guess, in this case, I was not panning the camera And it's not a backlight-scene.
Any thoughts?
Best regards,
da-mkay
