Question on image quality on Z50
EnjoyPics New Member • Posts: 14
The image on the playback display on the LCD monitor is consistently softer/contrast then the live view image on the LCD monitor no matter what settings I use. Is this effect inherent in the process of photography? Can the display image and live view image ever look exactly the same? This effect was observed taking pictures of live flowers in a vase on a small table and the camera was on a tripod. The settings I varied included VR, picture control, all the adjustments of factors within each individual picture control, backing off the aperture from wide open, shutter speed, and iso. Is this difference between the two images observed using Nikons best FF mirrorless camera, Z7II ? To be clear I like the images I am getting from my Z50. They are excellent. The clarity is amazing. I am just wondering why they are not exactly the same as live view which looks almost 3D. Thank you for your replies.
Nikon Z50 Nikon Z7
Franz304 Regular Member • Posts: 120
Re: Question on image quality on Z50
Do you have "Apply settings to live view" (d7) off perhaps?
OP EnjoyPics New Member • Posts: 14
I have apply settings to live view on. I forgot to mention I took pictures in jpg and also raw and I observed the same effect. It is a subtle effect but it is noticeable and consistent. It is so subtle maybe most people don’t know notice it. I am trying to learn more about my camera and was reviewing my images with a very critical eye.
topg Forum Member • Posts: 75
I'm not quite sure what you mean by "consistently softer/contrast" as your description is quite vague, but generally it shouldn't be a surprise that a live image stream would be different from a processed lossy jpeg view - even for RAW files, what you see on screen is a processed jpeg preview, but remember that you'll only get the full resolution preview if you zoom in 100% or more.
If you've turned off all processing options like noise reduction, and are outputting highest size/quality jpegs, and previewing them zoomed, you might assign to one of your function buttons the Preview option, which will show more accurate depth-of-field and some other characteristics before taking the shot. I assign it to the movie Record button.
I will have to try turning off noise reduction and any other in camera corrections and see what that does to image quality. I did not realize when you select raw you still see a jpg image in playback display.
