New to sx530hs .... disappointed
Started Jan 31, 2021 | Discussions
Sandancer72 New Member • Posts: 8
Hi , I picked up a as new sx530hs this week and was looking forward to rekindling the slr hobbie of my youth .
im posting for some thoughts on image quality . I love the compact size and zoom capability, and after taking the obligatory photo of the moon , took it out for the weekend .
My thoughts are that the image quality is worse than what my iPhone 11 takes , am I being too harsh ?  I love the idea of the camera and was wondering if maybe the sx70 is a better option or even another brand ! Or am I simply expecting too much from a £120 bridge camera ? Happy to hear your opinions
Canon PowerShot SX530 Canon PowerShot SX70
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Re: New to sx530hs .... disappointed
Looking at these ... not bad ... you need to sharpen with pp software
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
OP Sandancer72 New Member • Posts: 8
Hi Sue Ann , yes I always tweak the photos I take in Snapseed, these are as camera took them. But that’s what I’m getting at , they just feel a bit fuzzy
Sue Anne Rush
Maybe you got a lemon?
dan the man p Senior Member • Posts: 1,201
The quality of the photos you posted is probably about what you should expect. The iPhone 11 will run circles around any small-sensor compact in terms of image quality. Camera makers can only do so much with a tiny sensor, tiny superzoom lens, and none of the computational tricks that the phone cameras use. The only reason to buy a camera like that is if you really want the zoom.
 dan the man p's gear list:dan the man p's gear list
Sony DSC-RX0 Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 40mm F2
Thanks Dan ,
yes I’ve read up on it a bit today . I’m comparing to my 35mm transparency film photos from years ago and that explains the difference in quality with a 1/2 inch sensor . I love the zoom but struggle with the image quality. At the end of the day no big money spent so just a lesson learnt
jshen808
jshen808 Forum Pro • Posts: 16,067
Your pictures looks "okay",
not sure if you tried tweaking the settings.
But I do think you will get "better" pictures from the SX70 camera.
Can see the below link for a post I just did showing 2 out-of-camera SX70 pics.
https://www.dpreview.com/forums/thread/4551637#forum-post-64812878
Cheers!
Cheers, John
(Feel free to download my pictures)
*** Photography is about fun ***
*** No response = ignore list ***
 jshen808's gear list:jshen808's gear list
Panasonic Lumix DMC-FZ300 Panasonic FZ80/FZ82
Anders_K Contributing Member • Posts: 896
You shot those pics with rather long focal lengths, so some blur is to be expected due to shake and lens quality.
Do some test shots with different zooms on a tripod (switch stabilization off in the camera) and check picture sharpness on your PC.
This will give you more reliable information if it is really the camera that is below your expectation or if it had been just "you".
Yes I was at 50x zoom for the bird . I did do a wide angle test yesterday handheld but in good light and I would say quality is same as iPhone produces in those conditions.
I appreciate now the sensor size will limit image quality, but I do like the idea of the all in one package so might persevere as the light conditions improve .
Thanks for the link . Yes this camera seems very basic from the Pentax slr I used to have  and I miss having a view finder so I might upgrade soon the sx70 or have a look at some of the larger sensor bridge cameras . I appreciate your time sharing thanks
jshen808
No worries!
If go with say 1" sensor superzooms, the best is going to be a limit of 600mm.
Your posted bird picture was taken using around 1000mm, so 600mm won't do.
Depending on your camera hand-holding ability, can choose small or medium.
For a smaller camera, the Canon SX70 (21-1360mm) "new" is a good choice.
If can go medium size, the Nikon P900 (24-2000mm) "used" is a good choice.
The Panasonic FZ300/330 (25-600mm f/2.8 & 12mp sensor) is a fine choice too.
(1) SX70 vs P900
(2) SX70 vs FZ300/330 (FZ330 is the European model)
There is another camera for you to consider,
it's the Panasonic FZ80/82 (20-1220mm) camera.
(The FZ82 is the European model)
The FZ80/82 is often not recommended,
because it can be a difficult camera to master.
Can go over to the Panasonic forum,
look for the "FZ80 experiences" threads,
and take a look at the pictures posted there.
https://www.dpreview.com/forums/1033
Also can take a look at the FZ80/82 videos below.
https://www.youtube.com/c/GrahamHoughton12/search?query=80
https://www.youtube.com/playlist?list=PLFoIf_3ex-YLTm0kTaWkvd6HTen5ooN1K&pbjreload=10
(3) SX70 vs FZ80/82 (FZ82 is the European model)
Cheers!
Cheers, John
jshen808
..and here to compare between the SX530 vs SX70 cameras.
(1) SX530 vs SX70
Cheers!
Cheers, John
RLight Senior Member • Posts: 4,426
The SX530 uses OLD DIGIC4. Soft JPEGs, poor noise reduction, not so smart AF. I use bold letter rarely but I can't stress that it's the weakest link here enough. Post processing RAW is necessary to get more out of it.
An SX540 sports DIGIC6 which has newer noise reduction and AF. The SX70 HS is better still with the most modern smaller sensor and DIGIC8.
I should note, all of these cameras have smaller sensors which you're comparing a smartphone that also has a small sensor but has compute AI on it's side which these cameras, or any other non-smartphone, do not. Cameras like the SX530 have reach, which smartphones lack. But, if you're needing something other than reach? You should consider a larger sensor to produce higher image quality as the smartphone is going to win, easily, against any smaller format offering, even 1" G and RX series if you don't post process. You gotta step up to APS-C to make a dent. Trust me, just did it myself, and I'm not saying that because I did it, I did it because of image quality concerns, like yourself where I could've just whipped out my iPhone and done better for cheaper, lighter, but less fun.
The DIGIC4 won't serve you well if you don't intend to post though either way. Heads up. Canon made MAJOR changes to noise reduction with DIGIC6 and newer CPUs which makes a large difference if you're a SOOC JPEG shooter.
If you want reach, consider keeping it, or upgrading to the SX540.
But, you may want to consider say a Rebel SL2 or SL3 + EF-S 55-250, or M50 + 55-200. Doesn't have the (same) reach, but man, they have punch! And the M in particular is small for what it is.
Here's what this looks like in practice...
https://j.mp/3tirxjf
That M50 Mark II + 55-200 in paritcular, isn't that much heavier, bigger, and you can swap lenses... You may want to consider something more like an 70-300 IS II (not L) adapted though for more reach though if you're a birder...
 RLight's gear list:RLight's gear list
Canon EOS M6 II Canon EOS R3 Canon EOS R50 Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
marksee Contributing Member • Posts: 969
I recently purchased a Canon SX740 HS. I've had numerous Canon P&S cameras. The 740 was terribly out of focus on the long end. I returned it (a fefurb) and Canon sent me a new one within days. Maybe you have a lemon also. Oh, btw the new one is perfect.
Thanks for that post and those great images . What are these on again ?
I really don’t want to end up going down the slr route again with bags of lenses to carry so I think I’m going to sell this on and get the sx70. I just got it as an inexpensive trial to see what zoom was like and the general feel of a bridge camera .
this sx530hs has no view finder , no raw etc but it’s been good to get out snapping again
EOS M6 mark II. It’s a mirror less though, lens swaps. The M is sort of a large sensor power shot that you can swap lenses on. I hate bags, often I’d go out with just a 18-150 on it, or, say 55-200 + 11-22, etc, where I pocket a lens, no bag. 22 pancake and 18-150 is an excellent example.
Canons lacking in the bridge camera department. Their best option is the SX70 HS, but again, small sensor. You may be dissatisfied with the output. I’m on another thread about that very subject... It’s a hard one.
Essentially you have:
SX70 HS = reach but small sensor
FZ-1000 = reach, larger sensor but non canon colors, DFD focusing
EOS M = small but lens swaps
Canon never followed up with a G3X mark II, but rumor has it the mark I was a sales flop, so it’ll probably never happen leaving you with one of the above choices.
jshen808
It's always good to think of and have options.
Here is two out-of-camera jpgs from my SX70.
They are full-size, and are not post processed.
(Note: my SX70 uses the Hoya HD3 lens filter.)
(1) SX70 @ 21mm (widest)
SX70 @ 21mm (widest), out-of-camera jpg
(2) SX70 @ 1365mm (longest)
SX70 @ 1365mm (longest), out-of-camera jpg
Cheers!
Cheers, John
You mentioned it but didn't include it in your list: the G3 X. It has a 1 inch sensor and 25x zoom lens. It's an option for someone who really wants the larger sensor and long zoom in a fixed lens camera. Personally, for the price and size, I'd also prefer an EOS M50 (or other M) with 18-150 or 55-200 lens, though the reach is not as good.
Cheers!
Looks good to me. Good light = good results on smaller sensors.
I’ve thought about an SX70 for reach, but I’m HUGE on 24-70 as that’s what I shoot these days. Again, not too shabby.
have been looking now at the G3X , the sensor size looks like a great option ,
Sx70 vs G3X decisions decisions!
