xpatUSA
An SD15 Full Spectrum with Filters comment
Jan 30, 2021
Although a blue sky is said to be considerably darkened by such as yellow or orange filters on the lens, that is not my experience with the SD15. Instead, it remains at around mid-tone and changes color, usually to something ugly like cyan or greenish cyan or a yukky brown.
I put this down to the blue sky having plenty of emissive energy above the peak of 450nm or so, even including hefty amounts of near-IR. So, although these filters are said to "block" a blue sky, plenty of energy actually passes through these normally quite soft filters and is detected by all three Foveon F13 layers.
The following curves tell the tale:
At right, the middle one of the green curves is the Tiffen Yellow #12 that I received yesterday.
Here is a yellow #12 shot opened in RawDigger and shown in RGB mode:
It lacks contrast, has no vibrant Kodak reds or dark blues and does not smite my eye at all.
On the other hand, a brief play in RawTherapee produced this in-your-face image:
Not many will like this over-the-top rendition. However, it is posted to show the efficacy of post-processing with the goal of producing impressive images albeit not necessarily emulating Kodak Aerochrome or Ektachrome EIR.
In RT, I played with many functions but the main benefits [?] were from:
Haze Reduction, 3-channel Color Mixer and the White Balancer. The White Balance adjustments (temperature and two tints) were particular effective after messing with the Mixer! Continuous adjustment of the brightness, highlight compression and shadows was needed as stuff kept getting clipped or bottomed in the histogram.
RT Users can download the sidecar file from here (right-click then Save Link As ...):
http://kronometric.org/phot/ir/SDIM0825-RGB.pp3
It is a text file and non-Users can open it and have a guess at what was done (search on "Enabled=true").
Hope this is of some interest to a few of us ...
WYSINWIG: what you see is not what I got.
