Canon M50 Mark II - an underrated camera?
Started Jan 29, 2021 | Discussions
thunder storm Forum Pro • Posts: 10,139
Re: Canon M50 Mark II - an underrated camera?
KEG wrote:
Nigge wrote:
It is just to strange that Canon didn’t put the 32MP sensor in the 50ii. Why do they put in a dated sensor when they have a more up to date one??? Unbelievable.
Because:
  1. M50 is a budget camera
  2. canon is protecting sales of M6 mk II and RP by not using it
  3. In all reality the 24 MP sensor is actually really good
4.  It's possible to create decent AF improvements over the Mk1 even with the old sensor and same processor.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
KEG
KEG Veteran Member • Posts: 4,909
thunder storm wrote:
KEG wrote:
Because:
5. M50 was actually rather good in AF, especially for a budget cam
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
Risto456 Junior Member • Posts: 41
On the AF subject (hopefully I'm not hijacking the thread):
recently upgraded from the M6 to the M6.II, based on my experience with EyeAF on the RP.
Everything is fine with M6.II, but one thing I found a little disappointing, when tested side by side (the key test being done with 50mm on the RP vs 30mm on the M6.II): the RP's EyeAF was able to pick the eyes from over 10ft (3m) away, while the M6.II only from about 3ft (1m).
Probably most would say that at such distances the face detection would suffice, but I found the RP's behavior much more reassuring.
I'm wondering whether to go for the M50.II instead of M6.II if the AF behaves more like the RP (when the stock availability improves).
Would you know, especially the lucky few who managed to put their hands on the M50.II so far, if that behavior is similar there?
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
I've noticed this too, comparing the R with the M6II. I would say the R will pick up an eye from as far as 20 feet away with a 50mm mounted, and the M6II will get an eye from about 10 feet away with the 32 mounted. But the M6II tracks just as well as the R, if not better. All things considered, I would put the AF of the M6II and the R (and RP) as pretty much the same. I've never failed to get a perfectly sharp eye with the M6II, even when face detect only selects the face and not the eye. It could be that eye detect is working even when the square on the screen (or in the EVF) is only showing the face. As for the AF in the M50II, I would be very surprised if it were better than the M6II.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
nnowak Veteran Member • Posts: 9,074
The M6 II sensor comes off of Canon's newest fab line. The M50 sensor comes off of Canon's older line that also produces the R and RP sesnors.  The new line also produces the R5 and R6 sensors.
The most likely answer is production capacity.  Canon is not likely to throw the 32mp sensor in a high volume/low margin model like the M50 if there is even the slightest chance it might impact production capacity for the R5 and R6.  Frankly, for the M50 target market, the 24mp sensor is more than good enough.
Dlee13
Dlee13 Contributing Member • Posts: 716
7
I recently got the M50 Mark II and I honestly love it!
I had the M5 which when I got it at launch felt like such a great camera but in terms of AF, it is now showing its age. I feel the M series has so much potential and I enjoy using it but altering owning and using bodies like the A7III and R6 the M5’s AF was frustrating for me.
I feel the M50 Mark II’s AF is much closer to my R6 and I can happily use it without feeling like it’s a big step down. I will say I wish it had IBIS, I’ve become so used to dragging the shutter on the A7III and R6 that I often go too slow of a shutter speed on the M50 Mark II.
The only other annoyance is the lack of IR sensor. Even the R6 has one so I need to buy the BR-E1 just for the R6. Here’s a few photos with the M50 Mark II.
 Dlee13's gear list:Dlee13's gear list
Fujifilm X-S10 Sony a7 IV Sigma 56mm F1.4 DC DN | C (X-mount) Sigma 85mm F1.4 DG GN Sony FE 35mm F1.4 GM +2 more
