Close-up 3D with single shot - Samsung A12 entry level mobile.
Started Jan 26, 2021 | Discussions
tony brown Veteran Member • Posts: 4,387
Took a couple of pics in the workshop using new Galaxy A12 entry level mobile phone.
It takes portraits with single shot and creates a Depth Map. Used StereoPhoto Maker to extract the map and create stereo Anaglyph (Grey), Anaglyph (Dubois colour) and X-Eye versions herewith.
Wish it would work over greater distances but great for close-ups (up to about 8 feet).
Useful tool, and fun too! Know iPhone Pros work like this but for cheap phone, not bad. Whatever next?
Cheers, Tony.
BillAngel Regular Member • Posts: 200
Re: Close-up 3D with single shot - Samsung A12 entry level mobile.
I have a Samsung Galaxy A01 that also creates depth maps when taking pictures. Is there an application that runs on an Android phone that will create stereo pairs from these images?
 BillAngel's gear list:BillAngel's gear list
Nikon D100 Nikon D200 Nikon D300 Nikon D7100 Nikon AF Nikkor 50mm f/1.8D +5 more
OP tony brown Veteran Member • Posts: 4,387
I see talk of apps to run on iPhones but nothing much for Android. Personally, I download the images to Windows and use a very generously free program called StereoPhoto Maker which can do so much with your phone photos.
Others on this Forum may know of such.
Cheers, Tony.
Brian F Flint
Brian F Flint Regular Member • Posts: 184
In StereoPhotoMaker there is a tab (under Edit) which says 'open jpg include depth map'
What is this type of file. I guess it is a 2d jpg image with depth map information.
How do you create this file - or maybe I don't understand.
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
Your assumption is correct; 2D jpg image + depth map info.
Some phone cameras now create such files. Usually when used to synthesize Depth of Focus blur. They now include such entry level cameras like Samsung A12 which I just purchased. Mine produces depth map info to about 8 feet. Some expensive iPhones do better, I'm told.
Here is one such output jpeg and underneath is how it appears when opened in SPMaker followed by a cropped version of the resulting Dubois Anaglyph and the X-Eyed version.
Out of phone jpg
BTW, only cheap replica watches.
Cheers, Tony.
Brian F Flint
Tony Brown - Thanks for your explanation. I copied your image  ( the jpg of watches with the depth map  ) which gave me a jpg.  I tried to import this into StereoPhotoMaker  using - open jpeg using depth map - I got a ' cannot read file message'
Brian,
I have sentt you my email address privately. If you reply, I will send you the 'out of camera' file directly. It seems to lose the depth map data on DPReview's servers as a jpeg.
Cheers, Tony.
Brian F Flint
I received some original images from Tony Brown. Thanks Tony.
It turn out my problem was an old version of StereoPhotoMaker.
I down-loaded the latest version - StereoPhoto Maker Pro (64bit) Version 6.14
It is still free, even though it has the Pro in its tittle. This version dealt with the depth map ok.
