Polarized filter location - drop-in or at front element - any difference?
risto40
risto40 Regular Member • Posts: 357
Hi,
Just for curiosity, when you take a landscape photo of blue sky with wide-angle lense and use polarization filter on top of front element, you only get one spot/area of the sky polarized/darker. Whole sky is not evenly impacted. Is the result the same when drop-in polarizer is used (eg a polarizer in Canon EF-to-RF adapter) (because the location of the Polarization filter is at the back of the lens/closer to sensor, impact to the sky is much more even)?
 risto40's gear list:risto40's gear list
Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM Canon MP-E 65mm f/2.5 1-5x Macro Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III +3 more
Sittatunga Senior Member • Posts: 2,853
Re: Polarized filter location - drop-in or at front element - any difference?
risto40 wrote:
Hi,
It should be the same.  The effect is caused by the sky being polarised in the direction of the sun and at 90° to it.  The angle to the sun will change across the field of view of a wide-angle lens and that doesn't alter whether you put a polarised filter in front of or behind the lens.
You can check this just by looking through a filter by itself.
risto40
OP risto40 Regular Member • Posts: 357
thunder storm Senior Member • Posts: 6,423
risto40 wrote:
Hi,
I can confirm from my own experience Sittatunga is right.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS R Canon EOS M6 II Canon EOS R5 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 35-80mm f/4.0-5.6 III +17 more
