A7RIV prevent xml files saved with videos
Brett8883 Regular Member • Posts: 259
Whenever I shoot a clip there is also an xml file saved with that clip to the card. I don’t really see what use these xml files are and they just become a nuisance to delete so I am wondering if there’s a way to stop these files from being saved to the SD card in the first place?
Sony a7 Sony a7R
AlephNull Senior Member • Posts: 2,457
Re: A7RIV prevent xml files saved with videos
Two questions:
  • how big are these xml files?
  • how hard is it to delete them?
You might find that you can select the movie files independently, anyway.
 AlephNull's gear list:AlephNull's gear list
Sony a7R III Sony a7R IV Sony a1 Sony FE 85mm F1.4 GM Sony FE 100mm F2.8 GM +4 more
OP Brett8883 Regular Member • Posts: 259
AlephNull wrote:
Two questions:
Yes they are super small and can selected independently to be deleted but its just annoying. Say you have 50 clips you’d have to go through and select every other files to be deleted.
I was hoping there was a way to just turn this feature off so the files aren’t generated to begin with but I guess there’s not a way to do this.
Brett8883 wrote:
AlephNull wrote:
Two questions:
I wouldn't be surprised (I don't know) if these files serve a purpose akin to the XMP (aka "sidecar") files used by Photoshop - a tiny file used to carry metadata and ancillary information that avoids the need to alter the base file. Also means it can be the same format no matter the encoding used for the base file.
BTW: if you are using a GUI file manager, click on a different column heading to sort the files by file extension (or file type, or kind), instead of by file name, and all the XML files will be grouped together, so you can make a single contiguous selection - that's a lot easier than selecting every second file.
AlephNull wrote:
Brett8883 wrote:
AlephNull wrote:
Two questions:
They are actually more like EXIF data for the video. Just has like capture time date and settings which I guess could be useful for some people.
It’s a good idea to sort by file type and delete thanks
