Focus Peaking X-H1
21William Contributing Member • Posts: 599
Focus Peaking X-H1
I was happily using my X-H1 on a tripod with a manual lens and focus peaking was working great. I then moved backwards a bit and tried focusing again but the peaking had stopped. The focus on the rear screen was also very jerky. Any ideas. I hadn’t changed anything and double checked peaking was still turned on. It must be me but what have I done?
 21William's gear list:21William's gear list
Pentax K-5 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS
Fujifilm X-H1
AndyH44 Senior Member • Posts: 2,370
Re: Focus Peaking X-H1
"Jerky?" Sounds like it is not in Boost Mode, or it's going to "sleep".
"True craftsmen never blame their tools, but strive to use them properly"
 AndyH44's gear list:AndyH44's gear list
Fujifilm X70 Olympus TG-5 Olympus E-PL7 Fujifilm X-E2S Fujifilm X-T3 +1 more
OP 21William Contributing Member • Posts: 599
AndyH44 wrote:
Sounds like it is not in Boost Mode.
It is in Boost Mode but does it need to be anyway?
I went back to it and made some changes on the lens and peaking came back. Not sure why this should happen as it’s a Pentax fit Tamron 90mm Macro I was using with an adapter. I’m pretty sure I’ve had peaking stop before at one point.
baobob
baobob Forum Pro • Posts: 15,736
These kinds of things can happen with this electronic gear just switch oFF then on that should cure if not remove battery
I have no issue with mine whatever is the lens fitted on the body.
Sony RX100 Olympus Tough TG-4 Panasonic ZS200 Fujifilm X-H1 Fujifilm X-T3 +10 more
Yes I tried the turn it off and back on trick but it didn’t make a difference. Next time though I’ll try and remember the battery, thanks.
Vincent AF
Vincent AF Regular Member • Posts: 408
Did you accidentally turn the frontal lever back to Autofocus?
 Vincent AF's gear list:Vincent AF's gear list
Fujifilm X-Pro1 Nikon D800 Fujifilm X-H1 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G +10 more
No, it was on manual all the time.
SigmaChrome Forum Pro • Posts: 13,303
I don't think you've done anything wrong, William.
I have the same issues with the X-H1. It seems to reset itself if you change the focusing peaking mode. I find it quite annoying but not terminal.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma dp0 Quattro +36 more
Yes, you could be right. It is irritating that something works as expected one moment then for seemingly no reason stops working. There may be some logic to the programming but in practice it’s not so good.
Tim van der Leeuw Contributing Member • Posts: 533
What happens to me all the time on my X-H1, is that the "focus assist" method reverts to "STD" and I have to set it back to "Focus peaking".
Sounds like that's not what happened to you though.
 Tim van der Leeuw's gear list:Tim van der Leeuw's gear list
Canon EOS M5 Fujifilm X-H1 Fujifilm X-T3 Sigma 2x EX DG Tele Converter Canon EF 24-70mm F4L IS USM +12 more
BadExample Regular Member • Posts: 169
Does everyone with this issue have the latest firmware?
Yes, as far as I know. I didn’t update it that long ago, and the lens.
taichiplusart New Member • Posts: 18
It seems to be a power-saving feature. Half-pressing the shutter should wake it back up:
https://www.dpreview.com/forums/thread/4264786
Thanks for that. I’ll check if power save is turned on.
baobob
That should not impact when you come back FP should work again
On mine it works whatever are the settings
So many camera settings, so little time!
