SEL18 135 Firmware
hondav21098
hondav21098 Forum Member • Posts: 52
SEL18 135 Firmware
I have a NEX7 and want to put a SEL 18 135 lens on it. Do i have to load the firmware for that lens ???   Sony website says there is no downloads for it .
 hondav21098's gear list:hondav21098's gear list
Sony RX100 III Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Sigma 19mm F2.8 EX DN Sigma 30mm F2.8 DN | A +4 more
Sony Alpha NEX-7
geopapa Contributing Member • Posts: 693
Re: SEL18 135 Firmware
You'll probably be fine without an update. Make sure your camera runs the latest firmware
 geopapa's gear list:geopapa's gear list
Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Samyang 12mm F2.0 NCS CS Sigma 30mm F1.4 (E/EF-M mounts) +1 more
ManBOOYA Forum Member • Posts: 65
Sony cameras don’t need firmware for the lenses in 99% of situations.  I’ve read that Sony has the instructions for the camera in the firmware of the lens.  So whenever you put a lens on a camera it knows how to make it work
 ManBOOYA's gear list:ManBOOYA's gear list
Sony a6400 Tokina AT-X Pro 11-16mm f/2.8 DX Samyang 12mm F2.0 NCS CS Sigma 56mm F1.4 DC DN Sony E 16-55mm F2.8 G +1 more
Digital Nigel Forum Pro • Posts: 13,569
That's correct. All that the camera firmware updates seem to do for new lenses is to turn off the option to produce uncorrected JPEGs.  Sony only does this for heavily distorting lenses, where it would be embarrassed if customers realised just how much distortion and vignetting was being corrected in-camera.
All E-mount cameras,  from the NEX-7 onwards,  have automatic lens correction based on data provided by the lens. Even the original 2010 kit lenses provide correction data, so the system was designed into the lens mount right from the beginning, even though the original NEX-3 and NEX-5 cameras didn't do the correction.
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +19 more
You don't need to download anything. The lens will work just fine on the old camera, with automatic lens geometry correction working. The lens provides the correction data to the camera, without the camera needing to be updated or told anything about the lens.
Lenses can have firmware updates, but it's seldom needed or provided. When it is, it's for an older lens to work optimally on a newer camera which might have additional autofocus features that the lens can't implement without a firmware update. Generally, it's to get faster AF, but isn't often needed, particularly not with newer lenses.
Euell Veteran Member • Posts: 4,751
There is no firmware update for this lens.
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony a6500 Sony a7R III Canon EF-S 17-55mm f/2.8 IS USM +16 more
hondav2 New Member • Posts: 3
Thanks for the info. Much appreciated. Its working. I had a 18 105 on it but the smaller size, lighter weight and extra zoom attracted me to the 18 135. Just need to be able to travel again.
