How to find model # and Replacing battery for Macbook PRO 15" Late 2011
Bejersey
Bejersey Forum Pro • Posts: 14,302
First, How do I find the Model number of the Mac?  I entered the serial number and the model number didn't come up
And
Is this something I can do being technically challenged?
Rick
 Bejersey's gear list:Bejersey's gear list
Leica X (Typ 113) Canon G1 X III
Tom_N Forum Pro • Posts: 18,679
Re: How to find model # and Replacing battery for Macbook PRO 15" Late 2011
There's no need to find the marketing model.  Vendor sites usually display compatibility information in terms of the model name (e.g., "iMac (27-inch, Late 2009") and the model identifier (i.e. "iMac11,1").
For instance, on the Other World Computing site, one finds
Other World Computing – Newer Technology NuPower Replacement Battery for MacBook Pro 15" Unibody Early and Late 2011, Mid-2012
The battery on your MacBook Pro isn't soldered in.  That makes things a lot easier than if you had any of the Retina laptops.
The manual for your machine doesn't speak of the battery as being user-replaceable, but it speaks of the hard drive as user-replaceable and the RAM as user-installable.  So there are instructions in the manual on how to open and replace the MacBook Pro's cover.
The Other World Computing site has a video on how to install a replacement battery, and I see that that their battery kit includes the Philips and Tri-Lobe screwdrivers that you will need.
Bejersey
OP Bejersey Forum Pro • Posts: 14,302
Thank you so very much!!
Rick
Bejersey
Hi Tom,
To be clear...there is only one battery, the same battery, for all Late 2011 15" Macbook Pros?
Rick
Bejersey wrote:
Hi Tom,
Rick
As far as I know, there is only one type of battery for all 15" Late 2011 MacBook Pros.  If you are uncertain about compatibility, I would suggest contacting Other World Computing (or whatever other vendor you might be thinking about ordering a battery from).
