What settings can be saved in X-S10 Custom Settings?
Started Jan 18, 2021 | Questions
doak Regular Member • Posts: 244
I've read through the X-S10 manual and googled around some but am having a hard time finding a list of the settings that can be saved in the C1-C4 Custom Settings.
Really curious how complete the list is.  Thanks!
 doak's gear list:doak's gear list
Canon G7 X II Fujifilm X100V Fujifilm X-S10 Fujifilm XF 18mm F2 R Fujifilm XF 10-24mm F4 R OIS +6 more
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Re: What settings can be saved in X-S10 Custom Settings?
Pretty much everything in the IQ, AFMF and Shooting menus plus Shooting Mode, shutter speed, aperture, exp comp and drive mode.
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
OP doak Regular Member • Posts: 244
Thanks Greybeard!
How do you like your X-S10 vs the X-T3?  I'm considering trading in my X-T3 towards an X-S10?
Greybeard2017
doak wrote:
Thanks Greybeard!
I prefer the X-S10 - if it had weather sealing I probably wouldn’t use the X-T3 at all
Miller_bike Regular Member • Posts: 164
Movie settings cannot be saved in X-S10 Custom Settings?!
Digging up an older thread as relevant. I've been trying to assign a movie mode to a C setting on the X-S10 PASM dial as I want a quick way to switch between normal movie recording and high-frame rate for slo-mo. I have been unable to do this. The 'edit/save custom setting' option in the IQ menu is not present when the camera is set to Movie mode on the PASM dial. Which is annoying.
Is there any way to do this or do the C1-C4 settings only apply to stills? is there another way I could assign HFR Movie to a button instead of having to go into the menus? Going into menus is a real hassle when you're onsite and trying to capture the action.
Greybeard2017
Re: Movie settings cannot be saved in X-S10 Custom Settings?!
You can put it as the first item in the movie My Menu - that way it will be the first thing you see when you press the menu button.
The X-H2(S) cameras have much more sophisticated custom settings that haven't trickled down to the X-S10.
Great tip, have done that, thanks.
The Xh2 cameras look fantastic but they're expensive and way more capable than I need.
