Darktable favorites
Brad P Regular Member • Posts: 355
Darktable favorites
I'm a newcomer to darktable.  I cannot figure out how to establish a panel of modules that's always available everytime I open darktable and begin to process an image.  It seems as if the latest version (3.4) has eliminated a specific 'favorites' panel but I may be wrong about this.  At any rate, any help would be appreciated regarding how to set up my workspace so that a 'user defined' list of modules would be available at all times.  I understand how the various presets of each of the panels can be toggled on and off but these options don't provide exactly what I want.  Again - thanks for your help.
 Brad P's gear list:Brad P's gear list
Panasonic Lumix DMC-GX7 +3 more
FujiJon
FujiJon Regular Member • Posts: 290
Re: Darktable favorites
It's in the manual:
https://darktable-org.github.io/dtdocs/module-reference/utility-modules/darkroom/manage-module-layouts/
and
https://darktable-org.github.io/dtdocs/darkroom/interacting-with-modules/search-and-group/
If at first you do succeed, try not to look surprised.
 FujiJon's gear list:FujiJon's gear list
Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm 16-50mm F3.5-5.6 II
grcolts Veteran Member • Posts: 3,451
I don't find the new way of doing this very intuitive. I liked the old way better. Having said that, I find that the new linear scene module offers most of what I am using to process my images in DT anyway.
OP Brad P Regular Member • Posts: 355
Thanks to you both; I had checked the manual many times.  In the latest manual the relevant section is under .......module groups/layout manager.  Upon close inspection I finally figured out how to get what I wanted.
