I’ve found a good L-Bracket for the K-1!
Schleiermacher Senior Member • Posts: 2,369
Good L-brackets are expensive and sometimes difficult to source for the Pentax K-1 (and presumably K-1ii). I have found a good one for about $58.50 (US). It’s less than half the price of the $120.00 custom designed one for the K-1 made by Really Right Stuff.
Make and Model:
3 Legged Thing Ellie Universal L-Bracket with Shorter Base
Model #: Ellie-S-G
This model is adjustable and does not block access to the battery compartment door or to the HDMI/USB/DC-IN ports. When flush against the left side of the camera, it does slightly inhibit opening and closing the MIC/Headphone ports. I am able to open and close these covers but it’s a bit tight. I suspect that the adjustability of the unit would allow me to accommodate opening these two port covers more easily if I really needed access to them (but I don’t). Finally, the beveled rear of the bracket base does not interfere with the movement of the tilting LCD screen. Over all, it’s an excellent match for the K-1 (and other Pentax DSLR’S due to its adjustability.
It is also finely machined and very solid. It comes in two colors slate grey or copper orange.
3 Legged Thing makes many L-Brackets. Be sure to order the model above that is adjustable and has the shorter base otherwise the base plate will block the battery compartment door.
Pictures of it on my K-1:
Adjustable base and no interference with nattery compartment door
Cut-out accommodates opening door to lower side ports
Top of side bracket presses against the base of the mic/speaker port covers making access a bit tricky.
Beveled base accommodates full range of motion of rear LCD
The reason we love L-brackets!
Schleiermacher
www.mmathews.zenfolio.com
'At our best and most fortunate we make pictures because of what stands in front of the camera, to honor what is greater and more interesting than we are. We never accomplish this perfectly, though in return we are given something perfect -- a sense of inclusion. Our subject thus redefines us, and is part of the biography by which we want to be known.' --Robert Adams, Why People Photograph
 Schleiermacher's gear list:Schleiermacher's gear list
Panasonic Lumix DMC-LX5 Pentax K-1 Fujifilm X-T20 Pentax smc DA 70mm F2.4 AL Limited Pentax smc FA 31mm F1.8 AL Limited +11 more
Pentax K-1
Fotoni Contributing Member • Posts: 990
I'm using a cheap L-bracket made for D3200
Before selling the D3200, almost included the L-bracket with it until tried it with the K-1 just for fun. It is not top convenient because side connectors and the battery door are blocked. Does not fit 100%, but fits 99% and no real problems after a couple years. Paid about $20 from it. I'm just cheap if there is a way without real problems.
 Fotoni's gear list:Fotoni's gear list
Pentax K-1 Pentax FA* 50mm F1.4 SDM AW Canon PowerShot SD4000 IS
Pontoneer Veteran Member • Posts: 3,141
Re: I’ve found a good L-Bracket for the K-1!
Why would you bother with such a thing when you can just tilt the tripod head over to the side ?
I have always used Manfrotto 3D heads - such as the MN229 , which has a degree of freedom to do exactly this ; and a spirit level for each degree of freedom ( although the K-1 also has levels on the rear display ) and allows quick and simple changes from portrait to landscape modes .
 Pontoneer's gear list:Pontoneer's gear list
Pentax *ist D Pentax K-01 Pentax K-3 Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited +37 more
OP Schleiermacher Senior Member • Posts: 2,369
5
I use different tripods, including a light duty, travel one. If I drop the camera into the ballhead slot as required for portrait mode, it lowers the camera height (making it difficult to compose thru the optical viewfinder) and is difficult to level out in the field. L-Brackets such as this one don’t enable me to do something new; they enable me to do something I already do more easily with less fuss in the field. The ergonomics and simplicity are worth it for me and many others.
If you are happy without one, great!
For those of us who prefer them, this one is a great option.
Schleiermacher
tex Veteran Member • Posts: 8,491
Yes, I have this and it works great. /nt
tex_andrews, Andrews Fine Arts LLC, shooting professionally for mid-Atlantic U.S. museums with Pentax and Ricoh equipment, and occasionally Canon for video. Co-founder and webmaster of The LightZone Project, an all-volunteer group providing the free and open source LightZone photo editing software. Moderator at The Pentax Forums dot com
"Photography is the product of complete alienation" Marcel Proust
"I would like to see photography make people despise painting until something else will make photography unbearable." Marcel Duchamp
 tex's gear list:tex's gear list
Pentax 645Z Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 77mm 1.8 Limited +30 more
Gary Martin
Gary Martin Veteran Member • Posts: 4,828
I've been using the Kirk L-Bracket for my K-1 for several years now, but I see that it's no longer available. Glad to see we have other options, thanks for sharing.
 Gary Martin's gear list:Gary Martin's gear list
Ricoh GR III Pentax K-01 Pentax K-1 Fujifilm X-T4 Pentax smc FA 43mm F1.9 Limited +7 more
thanks. Another bonus is that this same model works on my very small Fujifilm x-t20 w/o blocking battery door. I’ve ordered a second one for that camera. Quite a versatile model.
Schleiermacher
gavinhw Regular Member • Posts: 136
Good to know that the Ellie Short works with the K -1 and some of the Fujifilms because I own Fuji bodies as well!
I bought an Ellie (regular) in copper orange and it also doesn’t block the K-1’s battery door.
After I’ve used it for a while, I’ll post a review. But briefly, I can say that it isn’t a perfect fit because it’s a generic L-bracket and thus does not enjoy the benefit of snugly resting against the contours of the camera body. Moreover, some of the other doors (mic., etc.) are blocked, but this is not an issue if you aren’t doing video.
I think for smaller primes, the bracket won’t rotate out of place when flipping back and forth between landscape and portrait so it’ll be fine. I will need to test whether using a heavy, long lens like the D FA 70-210 is problematic.
I apologize for the poor photo. I’m too
lazy to set things up properly.
Good find. I was curious too, and gave 3 Legged Thing a try over the Christmas holidays. See my other reply.
Here are photos I posted
over at the best Pentax website:
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/413407-l-plate-k1-mk-ii.html#post5089044
scroll down if you need to.
