Fujifilm x-t2, samyang 12mm. 30 sec, F2, iso 400.
Started 3 months ago | Photos
rakker2 Junior Member • Posts: 32
27
Comment & critique:
Fujifilm X-T2
MartinEA
MartinEA Regular Member • Posts: 440
Re: Fujifilm x-t2, samyang 12mm. 30 sec, F2, iso 400.
Excellent!
io_bg
io_bg Senior Member • Posts: 1,183
Great shot.
Since you're asking for critique, I'd try removing some of the vignetting as it's too much for my taste (I know the Samyang 12mm vignettes quite a bit wide open).
I'd probably also clone out the branches on the left edge of the photo.
And lastly, I'd take another frame just for the foreground (at lower iso and longer SS) and merge them together to benefit from lower noise in the lower part of the frame.
 io_bg's gear list:io_bg's gear list
Fujifilm X-T10 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm 16-50mm F3.5-5.6 II +7 more
Jerry-astro
Jerry-astro Forum Pro • Posts: 16,777
Terrific shot and an outstanding setting.  A quick suggestion or two... consider reducing your exposure time a tad to around 25s.  I shoot a lot of astro at that FL (but with a different 12mm lens) and you start getting some trailing and point distortion, particularly at the edges, when you shoot any slower than that.  Consider some careful NR on your finished image.  It will clean it up a bit, highlight the detail, and if you do it carefully, you won't lose much if any detail (i.e. stars).  Finally, you definitely have some room to increase your ISO, thus enabling an even faster shutter speed if desired.  I regularly shoot starscapes at ISO 3200 and still find the noise to be very manageable.  Even going to 800 or 1600 will help you gather more detail and allow you to hold your exposure time down.
Nice work!
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-H1 Carl Zeiss Touit 2.8/12 Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR +1 more
Merts Forum Member • Posts: 71
One word : Epic!
Fuji&Nikon&Mac
 Merts's gear list:Merts's gear list
Nikon D800 Fujifilm X-E3 Fujifilm X-T4
OP rakker2 Junior Member • Posts: 32
Thanks for your reply Jerry,
I will try your advices next time.
Erno
Thank you Merts
Thank you for your reply,
I will  try to do less vignetting en remove the branches.
I have never merge to pictures but will try it next time.
Erno
Thank you
SigmaChrome Forum Pro • Posts: 13,306
Beautiful shot, rakker.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma dp0 Quattro +36 more
