Em1 MK2 art modes in camera edit
RED i Senior Member • Posts: 1,845
Tested out Dramatic Tone yesterday but light was getting low and noticed I couldn't make ISO changes or other settings in camera while using the DT modes. Although the outputs were interesting the images was quite noisy.
I found one article saying that you can edit a raw image in camera and use an art mode on it. So I'm guessing this would allow me to do long exposure/low iso and then add the DT mode to the image?
(Yes I do take and have photos and they're grainy) http://bluei.ca
 RED i's gear list:RED i's gear list
Olympus E-M1 II Olympus 7-14mm F2.8 Pro Olympus 12-100mm F4.0 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic 8-18mm F2.8-4 +1 more
Olympus E-M1
Guy Parsons
Guy Parsons Forum Pro • Posts: 36,109
Re: Em1 MK2 art modes in camera edit
Or use Workspace to do it at leisure on a larger and nicer screen.
Sony RX100 VI Olympus PEN E-PL1 Olympus PEN E-PL5 Olympus PEN E-P5 Olympus OM-D E-M10 II +10 more
OP RED i Senior Member • Posts: 1,845
I don't use any compatible OS for Olympus software. In camera is ok.
Guy Parsons
OK, then edit in camera is possible. On my earlier Olympus bodies it is a matter of changing the jpeg settings and then editting the raw file using that setup. You can change jpeg settings as much as you like and make many new JPEGs from the same original raw file
CharlesB58 Veteran Member • Posts: 9,557
Dramatic Tone effect is going to increase noise because of the tone mapping element.
Photography is not about the thing photographed. It is about how that thing looks photographed. Quote by Garry Winogrand
http://ikkensimages.com
