Canon EOS 100D randomly stops recording
Started Jan 16, 2021 | Discussions
BluetheNerd New Member • Posts: 1
So I've had this issue since I bought the camera, I bought it second hand, and mostly wanted it for YouTube because even a cheap 1080p DSLR is an upgrade to a webcam, however the camera randomly stops recording. This issue is persistent every recording and the amount of time is random, at most it's recorded for over 30 minutes, at less it cut out at 9 minutes, or even today 20 seconds into the recording. The memory card is 32gb 30mb/s and I delete the videos off it before each recording so it definitely shouldn't be full, and the write speed should be fast enough. I use EOS Utility to shoot because the camera doesn't have a moveable screen so it's the only way I can see what I'm doing, it still saves videos to my cameras card and not my computer, although honestly it would be way easier if it did record to my PC because I wouldn't have to export, but I haven't found a way. Anyway that is off topic. Does anyone know why my camera randomly stops recording, or what I can do to prevent it from happening? It's not the batteries because the camera still has plenty, and recently I bought an AC adapter and the issue persists, so I'm really not sure what it is. Any help is welcome because I emailed Canon a week ago and they never got back to me.
Canon EOS Rebel SL1 (EOS 100D)
mdmarqphoto Senior Member • Posts: 1,460
Re: Canon EOS 100D randomly stops recording
It should always top recording at 29:59.  As far as the shorter times, it could be SD card performance/failure or overheating.  If you've tried a power adapter with a dummy battery that should rule out a weak battery.  I'd try a different SD card first.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
rmexpress22 Senior Member • Posts: 2,304
Try formatting the card every time instead of just deleting the files. It should give you better performance.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
RedFox88 Forum Pro • Posts: 30,738
Which brand and model of memory card? Not all work great for video, regardless of the speed listed on it.
Michael Thomas Mitchell Forum Pro • Posts: 12,158
That 30 MB/s is very likely a READ speed and not a WRITE speed. Most cards write slower than they read. My SLOWEST SD card is 95 MB/s (633x). It won't handle 4K on the 5DIV so well, but  1080/60 is fine.
A 30 MB/s card is quite slow these days. I'd recommend you spend $25 and dramatically upgrade both your speed and capactiy.
 Michael Thomas Mitchell's gear list:Michael Thomas Mitchell's gear list
Canon EOS-1D Mark II Canon EOS 7D Mark II Canon EOS 80D Canon EOS 5D Mark IV GoPro Hero7 Black +6 more
