AF jittering problem
Started Jan 16, 2021 | Discussions
StuartT50
StuartT50 Regular Member • Posts: 198
I was using a 750D today in full daylight and a Canon 17-55mm f/2.8 IS USM lens.
I noticed that on half pressing the shutter release the lens was jittering in and out and seemed unable to focus. I am using one shot AF mode and manual selection 1 point AF (the centre spot)
I know AF can be tricky in low light, but this was a sunny day and a static subject (a lake)
Anyone have any suggestions?
 StuartT50's gear list:StuartT50's gear list
Canon EOS Rebel T6i Canon EF 400mm f/5.6L USM Canon EF-S 17-55mm f/2.8 IS USM Tokina AT-X Pro 11-16mm f/2.8 DX Canon EF-S 18-55mm f/3.5-5.6 IS II
Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
Digirame Forum Pro • Posts: 41,857
Re: AF jittering problem
Did you swap out the lens, to isolate the problem?  Do you know if it's a problem with the lens or the camera?
StuartT50
OP StuartT50 Regular Member • Posts: 198
Ah. I didn't try that. I shall. Thanks
rmexpress22 Senior Member • Posts: 2,304
Even in full daylights, AF points still need contrast/lines to focus on. If you were aiming at a part that had low contrast the camera might not be able to find anything to focus on.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
StuartT50
Maybe I should just use the 19 point automatic selection instead. Perhaps that's more idiot proof.
I never really know which AF mode to use
Most of the time, I use 9 point autofocus selection in the center with my Canon T7i (800D) cameras. I have to be careful with that, to make sure that the autofocus is precisely where I want it, because it can mess things up, when the depth of field is shallow (like when using a telephoto lens). So, when I use it, I carefully note where it is being focused. Most of the time, it's OK doing it that way.
StuartT50
I think I just have the mode with the single spot in the middle. I put that on the object I want to focus on, then keep the shutter half pressed and recompose to get the shot i want.
I think with the 9 point mode, you have to manually select one of the points, right? How is that more efficient than just using the centre spot and recomposing?
(apologies for the rookie question!)
I would suggest picking the 9 point autofocus selection.  Then half-press the shutter and watch what you see in the viewfinder.  Do that a number of times, so you can see what the camera does.  There might be also something on Youtube that would help explain it in detail visually.
