C&C Sunsets
gavin
gavin Veteran Member • Posts: 7,954
C&C Sunsets
No travelling so everything is local. 3 different sunsets from around here.
Cuvier Park
La Jolla
Del Mar beach
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
embie
embie Senior Member • Posts: 2,441
Re: C&C Sunsets
Nice, but a bit overdone ?
"Travel is fatal...for prejudice, bigotry and narrow-mindedness" (Mark Twain) - "The world...is our home" (eMBie)
You can edit and repost my pictures until you drop but they will still be mine Please respect my copyright
 embie's gear list:embie's gear list
Nikon D7200 Panasonic Lumix DMC-FZ200 Olympus TG-5 Nikon AF-S DX Nikkor 18-140mm F3.5-5.6G ED VR Nikon AF-P 70-300mm F4.5-6.3G VR +2 more
David1961
David1961 Senior Member • Posts: 4,321
Re: C&C Sunsets
I like them all, especially the colours.
The horizon in the first one appears to be a little crooked?
Thank you for sharing
 David1961's gear list:David1961's gear list
Canon EOS 90D
KENTGA Veteran Member • Posts: 7,069
Re: C&C Sunsets
As mentioned, a little over done with the colors. aside from that I don't care for # 1 at all and I would crop # 3 and I love # 2. You asked for C & C. Normally I would not have been that critical of photos.
Nice photos.
Kent
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Canon EOS 5D Mark IV +15 more
Graham Meale
Graham Meale Veteran Member • Posts: 3,313
Re: C&C Sunsets
I'm surprised to see people comment that they're "overdone". Sunrises and sunsets are probably the only instances in nature that can't be "overdone". Perhaps the colours weren't this vivid. Perhaps they were more vivid. It's only possible to know if you were there and witnessed the spectacle. Maybe the people who claimed they're "overdone" live somewhere where beautiful sunsets never happen?
 Graham Meale's gear list:Graham Meale's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 50mm F1.8 II Canon EF 100mm f/2.8 Macro USM +7 more
Lan Senior Member • Posts: 2,647
Re: C&C Sunsets
A very nice set Gavin; love those bold sunset colours. For me the third one is the best.
Agree with David1961 about the tilt on the first shot though.
mfinley
mfinley Senior Member • Posts: 4,893
Re: C&C Sunsets
A nice consistent color range to the set.
If you're looking for C&C - For number 2 the framing with 80-90% of the image is the sky, I don't think the sky truly supports that much dominance, it loses me a lot in the upper left-hand corner, as all of the visual interest to me is in the lower 2/3rds of the sky
The last one is interesting with the heavy lower vignetting. If we are C&Cing it, I think it works as you framed if you take it back into post-processing and get some of the color into the right-hand side or look at another version with another crop to get rid of the too-dark less interesting dominating right side and bring focus to the main part of the scene with the surfer exiting off-center onto the right. A final pro level tip if you're interested - whenever you're shooting something like this, unless you're really excellent at your timing, something to think about is to shoot 3-4 frames so you have a choice to pick one where the surfer's legs are in the best position.
Purely personal opinion, scenes like these have many interpretations and most of what I wrote is purely nit-picking.
 mfinley's gear list:mfinley's gear list
Olympus 7-14mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0
gavin
OP gavin Veteran Member • Posts: 7,954
Re: C&C Sunsets
Thanks. I think I did crank up the saturation a bit too much. I use Adobe RGB on my calibrated monitor so I should switch to sRGB before I post.
gavin
Re: C&C Sunsets
Thank you for your detailed inputs.
gavin
Re: C&C Sunsets
Thanks. now that you mention it I notice it myself too!
gavin
Re: C&C Sunsets
Thanks. Probably screwed up the leveling when I was editing 1.
gavin
Re: C&C Sunsets
Thanks. I was a bit concerned about the saturation.
David1961
Re: C&C Sunsets
There is no need to switch to sRGB before posting as long as you embed the working colour space you used to create the image (in this case Adobe RGB) into the output image file.
Most, if not all, of the modern browsers use colour management and so they will convert the image colours to the browser's working colour space, typically sRGB.
If using something like Photoshop or Photoshop Elements, using File->Save  or
File->Save As automatically prompts to embed the working colour space into the output image file.
Canon EOS 90D
