a few questions about My Modes
OutsideTheMatrix
OutsideTheMatrix Veteran Member • Posts: 7,837
Hi I have a few questions about My Modes.
When switching between My Modes assigned to dial positions, if I turn the dial when I'm in one mode to switch to the other without turning the camera off first, will that corrupt or mix the settings differences between the two modes or are the settings of each mode permanent and immutable?  Going from regular Manual mode to MySet 1 involves "jumping" over Movie mode, if I do that with the camera on will that mix up my Movie mode or regular Manual mode settings with My Set settings?
Also, I use the Fn1 button for AFL lock and let's say I switch the dial position to go from one mode to another mode, will focus lock be maintained or do I have to do that again? I think the only thing that removes focus lock is actually turning the power off correct? (Not even the camera going into sleep mode ends focus lock does it, even though the LCD is off?)
In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist. We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
-Dwight D. Eisenhower, 1961
 OutsideTheMatrix's gear list:OutsideTheMatrix's gear list
Nikon Coolpix P900 Olympus PEN E-PL6 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +9 more
Denjw
Denjw Veteran Member • Posts: 6,733
Re: a few questions about My Modes
Which camera? Answers below based on E-M1X.
No but there maybe a short delay before the change of mode takes effect if the camera is still buffering/writing to card.
No.
As long as your Fn settings are the same in each mode it should be still be maintained. It does with AF limiter.
Why not just try it yourself?
I assign my Custom Modes to other buttons so I can switch with a button push and not have to turn the dial. But I am not sure which camera you are using so assigning modes to buttons may not be available.
 Denjw's gear list:Denjw's gear list
Olympus E-300 Olympus E-30 Olympus E-5 Olympus E-M1 Olympus E-M1 II +17 more
OutsideTheMatrix
OP OutsideTheMatrix Veteran Member • Posts: 7,837
No.
Thanks it's for the EM10Mk2.  I did try it- by accident!  I was shooting a long timelapse sequence and accidentally turned the mode dial when I was trying to turn the other dial.  I didn't notice anything different but I wasn't too sure since it's hard for me to tell if focus lock is being maintained when it's dark outside.
I can assign modes to buttons, but all my buttons are used up with functions.
Guy Parsons
Guy Parsons Forum Pro • Posts: 36,064
Re: a few questions about MySets
First up, Olympus  "My Modes" belong to the E-PL1 era and earlier compacts. From about 2012 on for a while they  had "MySets" then from 2016 on some have "Custom Modes" and some dropped the idea altogether.
When switching between My Modes [MySets on the E-M10 Mk2] assigned to dial positions, if I turn the dial when I'm in one mode to switch to the other without turning the camera off first, will that corrupt or mix the settings differences between the two modes or are the settings of each mode permanent and immutable? Going from regular Manual mode to MySet 1 involves "jumping" over Movie mode, if I do that with the camera on will that mix up my Movie mode or regular Manual mode settings with My Set settings?
Whatever assigned MySet spot you land on, that is what the camera is configured with, no mixing happens. The camera can be off or on when you do that.
That you would need to test for yourself. Going to a new assigned MySet sort of resets the camera to a new starting point but the lens should be left where it was if you are not currently holding the shutter at half press (?).
That logically sounds correct. Or another half press, if that is how you initiate focus. If the camera is set to not reset the lens to infinity, then even a power off would not upset your focus.
Again, no point in asking us, or theorising, simply test it for yourself. My feeble guess is that it may depend on the power off reset to infinity setting, testing it will give you the answer.
Sony RX100 VI Olympus PEN E-PL1 Olympus PEN E-PL5 Olympus PEN E-P5 Olympus OM-D E-M10 II +10 more
OutsideTheMatrix
Focus is set to reset to infinity on power off, which I did to easily set infinity focus for astrophotography but it turns out using this gives me bloated out of focus stars....I guess this means it isn't true infinity?  I have much better results locking focus on a street lamp 150 ft away.  I have Focus Mode set to 3 so shutter half press only sets exposure.  So I take it only power off should unlock focus?
