Fuji xpro3 OVF focus box question
EyeNoAGuy New Member • Posts: 2
Hi,
I just bought the xpro3 and haven't been able to find anything regarding an odd display that only shows in OVF.
There's a solid box for where I'm focusing and then off to the bottom right of where the solid box is is another box, and this icon is a box with only with the box corners showing. The two are always near but off set from each other. Anyone know what this means?
Fujiukian Regular Member • Posts: 243
Re: Fuji xpro3 OVF focus box question
sounds like it telling you the frame outline for the image through the lens as opposed to the optical viewfinder. Does it change when you focus at infinity compare to close up?
 Fujiukian's gear list:Fujiukian's gear list
Ricoh GR III Fujifilm X100V Fujifilm X-Pro2 Fujifilm GFX 50R Fujifilm GF 32-64mm F4 +3 more
BryceM
BryceM Senior Member • Posts: 1,928
Camera Displays (fujifilm-dsc.com)
- International Man of Mystery
 BryceM's gear list:BryceM's gear list
Fujifilm X-Pro1 Fujifilm X-T2 Fujifilm X-Pro3 Fujifilm XF 56mm F1.2 R Fujifilm XF 16mm F1.4 R WR +42 more
Aoi Usagi Senior Member • Posts: 2,500
I believe you are referring to the Corrected AF frame.
The Shooting Menus (AF/MF SETTING) (fujifilm-dsc.com) (scroll down to the bottom).
Formally Evogt500
 Aoi Usagi's gear list:Aoi Usagi's gear list
Fujifilm FinePix S200EXR Sony Alpha NEX-5N Fujifilm X-Pro1 Sony Alpha NEX-6 Canon EOS 70D +2 more
OP EyeNoAGuy New Member • Posts: 2
Wow, that's awesome, thank you so much!
