Grandma in Doghouse Olympus Stylus 600 6.0 mp Factory Reset Fix Settings
Chris16 New Member • Posts: 2
Ordered a camera for granddaughter to learn basics of camera use. Settings were good and pics were clear but when I went to fix the flash/on off today and looked at various settings, - I must have pressed something that is now making all the pics blurry. I think a change to the xxx X xxx setting might be the issue but not sure. (was trying to get it as close to HD as possible -for some reason, the top 2 HD settings were not selectable)
Researched, tried changing from Scene Mode "Portrait" to Blurry one - but seemed to make it worse. Put back to Portrait and not sure what else to fix.
When I press: "SCENE" button is shows the following settings along bottom:
HQ 2816x2112 ... xD with 613 under it in green
I've tried to find how to fix it on the Olympus site - but can't find the answer.
https://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1190#39
Is there an easy way to factory reset to normal/everyday settings? If not, can someone please advise how to correct the issue? Granddaughter is frustrated w me now, I'm frustrated I messed it up!
Thanks greatly!
Grandma
olytopeka Forum Member • Posts: 80
Re: Grandma in Doghouse Olympus Stylus 600 6.0 mp Factory Reset Fix Settings
I don't have that camera, but pg 83 of the manual tells how to do a factory reset:
https://www.olympusamerica.com/files/oima_cckb/Stylus_600_Mju_Digital_600_Advanced_Manual_EN.pdf
Hope that helps,
Paul
 olytopeka's gear list:olytopeka's gear list
Olympus XZ-1 Olympus SZ-30MR Olympus Stylus 1 Olympus OM-D E-M5 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +4 more
