Macro lens?
Terry K1
Terry K1 Senior Member • Posts: 1,444
Macro lens?
Hello,
Is the 80mm a true macro lens?
 Terry K1's gear list:Terry K1's gear list
Sony a7R IV Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 16mm F1.4 R WR +3 more
XEddieX
XEddieX Contributing Member • Posts: 760
Re: Macro lens?
It's a 1:1 reproduction lens.
2x X-T2/VPB | Zeiss 12 ƒ2.8 | 16 ƒ1.4 | 35 ƒ1.4 | OM 50 ƒ1.2 | OM 50 ƒ2 macro | 56 ƒ1.2 | 90 ƒ2 | 18-55 ƒ2.8-4 | XF 16-55mm ƒ2.8 | XF 50-140 ƒ2.8 | RRS |
Tim van der Leeuw Contributing Member • Posts: 537
Re: Macro lens?
What do you consider a true macro lens?
It has 1:1 reproduction, does that mean it meets your criteria?
For me it does -- 0.5x reproduction for me is not "true macro" but 1:1 does for me. Although I'd love 2x reproduction but I guess that for that I'll add extension rings at some point.
If 1:1 reproduction rate is not good enough for you then there are manual focus macro lenses from Laowa of course which have 2x reproduction rates or more
 Tim van der Leeuw's gear list:Tim van der Leeuw's gear list
Canon EOS M5 Fujifilm X-H1 Fujifilm X-T3 Sigma 2x EX DG Tele Converter Canon EF 24-70mm F4L IS USM +12 more
a_c_skinner Forum Pro • Posts: 10,720
Re: Macro lens?
Reproduction ratio as a measure of how close you can get is irrational. For a full plate camera 1:1 will fill the frame with an object about 200mm across. For a smart phone 1:1 will fill the frame with a 7mm object.
For APS-C 1:2 is close to 1:1 on full frame.
Is the 80mm a true macro? Honestly you need to frame your question better to find out about that or any lens. No one has a definition of true macro and the 1:1 so beloved of people on here, who presumably don't do much close up photography or haven't reflected a lot on it, came about when 135 film (36x24mm) was hugely more common than any other frame size so at least then it had some utility as a widely applicable measure of how close.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Terry K1
OP Terry K1 Senior Member • Posts: 1,444
Re: Macro lens?
Thank you very much.
Terry K1
Re: Macro lens?
Yes. That would be nice.
Terry K1
Re: Macro lens?
Thank you Andrew.
Re: Macro lens?
I should say of the 9 macro lenses I've used over 40 years the Fuji 80mm has been the best.
Andrew Skinner
JayPhizzt Senior Member • Posts: 1,929
Re: Macro lens?
Terry K1 wrote:
Hello,
If you by "true macro lens" mean 1:1 magnification then yes. Else I don't know what you mean by "true macro lens".
 JayPhizzt's gear list:JayPhizzt's gear list
Fujifilm X-T3 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 80mm F2.8 Macro +1 more
