Stopping down a mirror lens
Started Jan 14, 2021 | Discussions
Karl Persson Regular Member • Posts: 246
Mirror lenses have fixed apertures, they can´t be stopped down.
Well, they actually can. I´ve seen examples where a section of the front has been covered.
But I have a better idea.
I made a 5mm wide ring (in plastic) to fit inside the filter thread and put it on my Samyang 300/6,3 mFT lens.
Not only did it stop the lens down by ~2/3 stop, it transformed the lens from unusable to nearly usable
So, if you have a better mirror lens, that is close to usable, you might be able to make it usable with the discribed method.
rubank Senior Member • Posts: 1,325
Re: Stopping down a mirror lens
The proper way to stop down a mirror lens
is into a garbage bin
(joking, couldn´t resist)
petrochemist Veteran Member • Posts: 3,619
I've done similar things with black card/thick paper, but for projector lenses rather than a mirror lens.
I found my 300/6.3 to be quite good straight out of the box, I think I actually prefer it to the 100-300 I subsequently got!
It's probably worth the investment to try the trick on my other mirror lenses
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Apertures for mirror lenses
That will give you even worse (thinner) doughnuts.
You can actually end the doughnuts entirely by making a front-mounted stop that has a hole that fits between the outer edge of the lens and the inner blocked circle. It doesn't matter that the hole isn't centered; it still works as an aperture. It will stop the lens down a lot -- typically about 4 stops minimum. That means your f/8 mirror becomes more like f/32, which implies resolution will be diffraction limited and any tiny spec of dust on your sensor will make a crisp shadow (i.e., you'll need to clean your sensor).
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
