long exposure noise reduction issue (X-T100)
Started Jan 13, 2021 | Questions
KneeConWon Contributing Member • Posts: 810
What's going on here?
Long Exposure Noise Reduction (LENR) turned off:
Crop of upper-left corner:
LENR turned on:
As you can see, the image with LENR turned on looks redder, noisier, and more sharpened (over-sharpened).
Of course, I appreciate that the hot pixels have been removed, but why are these negative side effects happening? And is there any way to avoid these artifacts in-camera while keeping LENR turned on?
I've never experienced this issue on my Nikon cameras or Sony camera when doing night photography. I love the X-T100 otherwise.
All of the above images were shot on a tripod, in JPG, and are straight out of camera.
Any clue what's going on here? And have you ever seen this before on any camera?
 KneeConWon's gear list:KneeConWon's gear list
Sony a7 II Nikon D7500 Fujifilm X-T100
Erik Baumgartner Senior Member • Posts: 6,893
Re: long exposure noise reduction issue (X-T100)
Did you take the NR On shots second? Could be the sensor heated up more and became noisier.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP KneeConWon Contributing Member • Posts: 810
Yes, it was the very next shot.
Interesting theory. I'll have to check to see if subsequent photos that night get progressively redder/noisier/more sharpened.
sluggy_warrior Veteran Member • Posts: 3,204
One way around it might be taking multiple short images, e.g.  5-second shot then pause for a second, median blending them in post. The sensor gets a bit of break in between, might help?
Thanks for the suggestion! I'll definitely try giving the camera a break between long exposures and see whether that helps the issue.
