Oly 60 macro - sharp where?
Started Jan 11, 2021 | Discussions
Gary from Seattle Veteran Member • Posts: 7,852
Re: Oly 60 macro - sharp where?
Adrian Harris wrote:
I received my Olympus 60mm macro last week.
A question regarding sharpness...
It is very sharp with close up subjects - as one would expect.
However - and I know it is not designed for this - when photographing subjects 40 metres/yards away it is only as good as my Panasonic 14-140 mk2.
I realise it needs to be optimised for macro subjects and hence distant subjects are not priority, but as a prime lens I had hoped it would be extremely sharp for far off subjects too.
I have sometimes used my 60mm macro as a short telephoto when I am out for macro shots and did not carry my preferred very sharp 35-100 F2.8. My experience is that when shot as a telephoto, the IQ is decent but not in the same league. That may be a bias for close-up photography, or it may just be that the lens does not reach the very good to excellent IQ range that the 12-40 and 35-100 reach.
So I am curious to find out if my copy is typical: Extremely sharp when subject close. Average sharp for distant subjects?
It is, though, a very good lens for macro - but it may be that when shooting macro one doesn't really evaluate images the same way as one would in shooting landscape. Still, it is capable of giving detail to tiny hairs on a plant for example. It is good enough for me to use the lens for identification of vascular plants based on hair details, and of the shape and size of teeth of certain mosses, also for identification purposes. For me, the 60mm lens meets my expectations.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus 12-40mm F2.8 Pro Panasonic Lumix G X Vario 35-100mm F2.8 OIS +7 more
kenw
kenw Veteran Member • Posts: 7,095
cba_melbourne wrote:
I see. Makes perfect sense now. Thanks for putting me right , I learned something today.
That's one of the things that makes it worth wading through DPR - we all get to learn things from each other along the way.  I know for me sometimes it even takes seeing the same thing a few times over the years before it finally clicks and I actually get it.
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Panasonic Lumix DMC-GM1 Nikon Z7 Panasonic Leica DG Summilux 15mm F1.7 ASPH Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +46 more
DrHook59
DrHook59 Contributing Member • Posts: 856
This is an interesting subject. I do not have the O60mm, but I do have the P30mm and I use it often for a walkabout 'single lens' solution when I think there is a chance of an insect or two.
Looking through the images I have taken with the lens, I've found no complaints regarding focusing issues at distance for the P30mm. I wonder if the difference in construction is the factor? My lens seems quite sharp, certainly sharp enough for me, but I wonder it it meets others' requirements. Here's one example....
_____________________________________
Some of the coolest things in life are really, really small.
https://www.flickr.com/photos/roddyhays/
 DrHook59's gear list:DrHook59's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Sigma 60mm F2.8 DN Art Panasonic Lumix G 42.5mm F1.7 Panasonic Lumix G Macro 30mm F2.8 +2 more
(unknown member) Forum Pro • Posts: 19,317
Its why i never bought one. as my oly 14 150 with 2 stacked canon filters was sharper at 1:1 now i just picked up a new 18 135 lens for my sony and with the same filters it blows my fav macro set away Im impressed.
Don
Olympus EM1mk2, Sony A7r2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1 em5mk2
Valdai21 Regular Member • Posts: 375
From my experience, Olympus 60mm should be a very sharp lens at all distances.
However I owned about 4-5 samples in the past years because of my love-hate relationship with this one. Two had unreliable focus at infinity but were sharp focused manually. One of them was even worse than that at medium distances.
Try cleaning lens contacts and focus manually if you need critical sharpness at long distances.
EspE1 Senior Member • Posts: 1,448
Traditionally macro lenses from Olympus has been optimised for a focusing distance where the subject is rendered 1:10 on the sensor, whereas other lenses normally has been optimized for infinity. An exception was the 80 mm macro lens for the OM-system, (which needed to be mounted on a bellows), it was designed for an optical optimum at 1:1, hence very good for copying of film/slides.
If this is still correct for the 60 mm, I don't know.
But from this I would in general basically expect the quality of the image from a long distance shot with a macro lens to be roughly comparable to an image shot with a non-macro lens at minimum focusing distance - they could in both cases be expected to work at the limit of what is acceptable optical quality, (which means that making the focusing distance even shorter than minimum focusing distance would result in unacceptable images quality - longer than infinity is not neede to make any spesial fuzz about ....).
 EspE1's gear list:EspE1's gear list
Olympus E-5 Olympus E-1 Olympus E-M1 Olympus E-M1 III Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +22 more
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
Thank you for posting an example. On cursory inspection the edges look sharp, but there doesn't seem to be a lot of texture showing in the stonework, I am assuming this may be a compressed JPG. Or possibly its just me expecting to much from my lens?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Sony SLT-A77 Olympus E-M1 II Panasonic Lumix DMC-G1 +1 more
(unknown member) Senior Member • Posts: 1,452
DOnt like that lens, hard to use switched to Panasonic.
DrHook59
I'm not sure how to load photos on here that are original size, Adrian, so not sure what version has popped up here. I can send you the original if it helps, just let me know in a PM how to do it.
Do you visit the m4/3 site at all? There is a showcase thread there with a couple of hundred pages of images from the O60mm. There are several recent landscape photos, too. You can find it here .
HTH
Adrian Harris
HTH
Thank you for your offer DrHook. I shall do a few tests myself tomorrow to check properly how my lens is performing and report back if I still have doubts.
strawbale Senior Member • Posts: 2,453
see Roger Cicala's "Understanding field curvature for fun and profit (part 2)"
from last Monday's https://www.dpreview.com/opinion/7031211310/roger-cicala-field-curvature-pt-2:
" It’s most common in lenses that allow close focusing, like macro lenses (most macros have flat fields at macro distances, curving fields at normal distances" (Field Curvature Variation paragraph)
Sigma 56 f/1.4 or (used) 60 f/2.8 ?
Will be better allrounders.
Adrian Harris
Re: see Roger Cicala's "Understanding field curvature for fun and profit (part 2)"
Unfortunately that link no longer works.
This one should (without the semi-colon at the end):
tedolf
tedolf Forum Pro • Posts: 29,548
Thanks.......
Guy Parsons wrote:
Funnily enough back in my Nikon film days the Nikkor 60mm macro lens had the "not so good at distance" reputation. I had one and yes it seemed to be true, sold it and bought their 105/2.8 macro for other reasons, eventually sold that too as I wasn't using it enough anyway.
So back to Olympus, that seems like a gentle challenge to do some distance shots with macro lenses and regular lenses and see what happens. In my case it would be...
  • 60mm macro vs 35-100/2.8 at 60mm
  • 4/3 50mm macro vs 35-100/2.8 at 50mm
  • 4/3 35mm macro vs 35-100/2.8 and 12-40/2.8 at 35mm
Don't wait up as that will take some time to organise.
Thanks Guy. I am looking forward to this.
I have heard good things about the Olympus 30mm f/2.8 macro at normal focusing distances. I bought one on sale for $99.00 to duplicate slides but have not used if for anything other than macro.  Does anybody have any experience with that lens as say, a portrait lens?
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +9 more
Re: Thanks.......
Tedolph
Olympus 30mm 3.5 macro is very sharp at all distances in my experience. Very good landscape lens too.
I don't think the 60mm has field curvature. With macro lenses, you should beware of autofocus accuracy at infinity.
tedolf
Re: Thanks.......
Tedolph
Thanks for letting me know. I bought it for slide/negative duplication when it was on sale for $99.00.  Now I will consider it for other uses.
Still trying to figure out a jig for duplicating APS film negatives!
I do most of my focusing manually.
Tedolph
eques Veteran Member • Posts: 4,115
Oly 60 macro
When I buy a new lens, I ususally do a rough and ugly comparison with all the lenses I can get. I climb up a hill and take photos of the village I live in at several apertures. So the distance is near infinity.
My findings: near infintiy my sample of the 60mm is about as sharp as the Olympus f/4-5.6 40-150mm, but less sharp than the f/2.8 40-150 and the f/4 12-100. without direct comparisons I'd say it is as sharp as any Olympus pro lens from 0.4 - 10m.
BTW before I got the 12-100 I bought a PL 12-60 and found the sample very soft at 45mm in the outer 2/3(!) of the frame - very much inferior to the ancient Panasonic 14-45. So I sent it back and got the 12-100.
So perhaps you should try to get a better sample.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Olympus 12-100mm F4.0 Panasonic Lumix G 20mm F1.7 ASPH
Adrian Harris
Re: Oly 60 macro
Peter
Hi Peter, that's very good advice. I did in fact do something very similar in practical terms, except I tried it on two cameras, as I found in the past that apparent lens issue's can actually be the camera at fault!
Although my copy of the 60 macro appears a touch soft in the bottom left corner, other than that it is very sharp. And for all intents and purposes in all practical working situations where I am likely to use it it is really good throughout.
I only bought it for macro work, so my expected use will be close subjects and f settings preferably between f4 and f9 where it should be working at its optimum.
For other subjects the focus system is far too slow to be of practical use for any of my other favoured forms of photography.
Bassam Guy Veteran Member • Posts: 4,887
The sky was pretty clear yesterday when I took this picture from the end of the reflecting pool with the Lincoln memorial at my back - 3750 ft.
Judge for yourself but IQ is reduced by DPR.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +8 more
