Oly 60 macro - sharp where?
Started Jan 11, 2021 | Discussions
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
I received my Olympus 60mm macro last week.
A question regarding sharpness...
It is very sharp with close up subjects - as one would expect.
However - and I know it is not designed for this - when photographing subjects 40 metres/yards away it is only as good as my Panasonic 14-140 mk2.
I realise it needs to be optimised for macro subjects and hence distant subjects are not priority, but as a prime lens I had hoped it would be extremely sharp for far off subjects too.
So I am curious to find out if my copy is typical: Extremely sharp when subject close. Average sharp for distant subjects?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Sony SLT-A77 Olympus E-M1 II Panasonic Lumix DMC-G1 +1 more
Panasonic Lumix G 14mm F2.5 II ASPH
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
Re: Oly 60 macro - sharp where?
Hmm, I do not think sharpness of a lens, macro or not, should change at all with the distance. If yours does it may have a focusing problem.
But Maybe what you observe are generally softer edges, as hinted at by the MTF chart. And not a general softness across the frame? See the chart below, the red and blue lines are unusually much apart with this lens, especially from fully open to about  f/5.6. That is the character of this lens.
https://www.lenstip.com/356.4-Lens_review-Olympus_M.Zuiko_Digital_60_mm_f_2.8_ED_Macro_Image_resolution.html
I have to admit that I never use the 60mm for anything other than close-ups. So I could not tell if your copy is typical.
 cba_melbourne's gear list:cba_melbourne's gear list
Olympus PEN-F Olympus E-M5 II Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 III +16 more
kenw
kenw Veteran Member • Posts: 7,095
9
The sharpness of a lens absolutely does depend on the focus distance which is precisely why they make dedicated macro lenses rather than just using extension tubes on normal lenses.
That said I’d expect a modern macro lens to perform great at long focus distances still. Most modern macro designs perform well throughout their focus ranges.
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Panasonic Lumix DMC-GM1 Nikon Z7 Panasonic Leica DG Summilux 15mm F1.7 ASPH Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +46 more
kenw
At what aperture are you making the comparison? For instance at F/8 at the center of the frame nearly all m43 lenses are very close in performance.
Ken W
Chris DC Contributing Member • Posts: 805
Adrian:
I have anecdotally observed that my various macro lenses (60mm Oly, 50mm 4/3 oly macro, 105 sigma 4/3) give lackluster overall image quality at distances more than about 20 meters.  Things in the images look "busy" and not smooth.  Nothing seems very sharp.
I have always attributed this to the fact that macros are optimized for flat fields and sharpness at or near the minimum working distances.  Just about any other lens I have gives me more pleasing distance results.
The macros work ok for portraits but I usually fall back on other lenses for portraits.  My favorite is the 35-100mm F2, SHG 4/3 lens. It is huge and heavy but never disappoints for portraits.  It doesn't focus close.
My takeaway is that I use macros for close up work and for landscape I rely on my other lenses.  For now my other lenses are all old big and heavy 4/3 lenses.  The newer mFT lenses seem to work well too.
I'd love to see some test data for the 60mm macro at far distances compared to other non-macro lenses but I have not found such data.
CDC
epozar
epozar Senior Member • Posts: 1,969
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko 300mm F4 IS Pro +10 more
ahaslett
ahaslett Forum Pro • Posts: 12,662
Chris DC wrote:
Adrian:
CDC
I have the FT Zuiko 50/2 and Sony 90/2.8, both exceptional lenses out to about 20m.  I still use the 90/2.8 for landscape, but it’s rather ordinary in terms of contrast etc at much over 20m.
I’d use a Panasonic or Olympus Pro zoom for tele landscape.  I was interested in the Zuiko 35-100/2 because of the excellent optical correction but it was always more than my budget, not to mention heavy.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Your experience with the 50mm F2 matches mine.  I cannot put my finger on the problem but as you noticed, images of far subjects just don't look great.
The 35-100mm F2 SHG is just another animal all together. The optical results are stunning but it is very heavy and large, focus speed is slow by today's standards, it doesn't focus real close and a nice example will cost you about $1000.
CDC
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
Thank you everyone...
...for confirming my findings.
I am not unhappy with the lens, it's macro performance is excellent and I have both Olympus and Panasonic pro lenses for other long distance subject if needed.
I love learning and was keen to hear others findings.
ahaslett
CDC
If I was doing landscape tele, I’d go for the Tamron 75-180/2.8 on my A7R2.  For the moment I’m quite happy with a 12-40 Pro and an adapted 50-200 SWD.  If serious, I can always use the Samyang 135/2, but you have to be very serious!
Andrew
Sounds like you have your bases covered.  I have been happy with the 50MPx files I get from the HHHR mode and my 14-35mm SHG lens.  The tripod mode is even better.
CDC
Re: Thank you everyone...
I got the 60mm to take advantage of the in camera focus stacking available on some Oly bodies.  It is super convenient and handy!
CDC
grcolts Veteran Member • Posts: 3,914
I have used my Olympus 60/2.8 macro for both close-ups and landscape/general nature and have been pleased with it. Some of my landscape shots taken with it almost remind of being 3D....anyway I can't complain about that lens.
cba_melbourne
Of course Ken. What I meant is that the sharpness of a lens, macro or not, should not change with the distance, provided it can be focused to infinity. Which is clearly the case with the Oly 60mm.
Yes. But the Oly 60mm has considerably softer corners than the center sharpness, IF and WHEN used at apertures between 2.8 and 5.6. Since one most usually closes the aperture further for macros and especially reproductions, nobody ever notices this. Until the lens is used like a normal lens.
The guys at Lenstip think, these softer edges at large apertures may be because of the unusual long and slender design of this macro lens. You can read about it in the link to their lens review from 2012 that I provided.
Anyways, it is an outstanding macro lens. Probably doubles as portrait lens too, where softer corners are usually desirable. But may not be the best lens choice for landscapes.
PS: note I and lenstip say softer. Because the lens is exceptionally sharp at the center, it is still acceptably sharp at the edges, even if these are considerably softer than the center. And it is only at the widest apertures anyway.
Astrotripper Veteran Member • Posts: 8,676
It can. Depends on the lens design. But in general, you cannot expect the lens to perform the same at infinity and at close distance. However, if there is a difference, it's usually not big enough to be obvious or even noticeable.
That can be the case. Best way to test, is to try using manual focus and see if it's possible to get a sharper image than with AF.
I have to admit I do not know how my 60mm compares to my other lenses. I took some portraits with it and maybe a few photos at "normal" distances and don't recall seeing anything bad. But again, without comparing side by side with another lens it's hard to tell unless it would be obviously bad.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Funnily enough back in my Nikon film days the Nikkor 60mm macro lens had the "not so good at distance" reputation. I had one and yes it seemed to be true, sold it and bought their 105/2.8 macro for other reasons, eventually sold that too as I wasn't using it enough anyway.
So back to Olympus, that seems like a gentle challenge to do some distance shots with macro lenses and regular lenses and see what happens. In my case it would be...
  • 60mm macro vs 35-100/2.8 at 60mm
  • 4/3 50mm macro vs 35-100/2.8 at 50mm
  • 4/3 35mm macro vs 35-100/2.8 and 12-40/2.8 at 35mm
Don't wait up as that will take some time to organise.
kenw
No, again, the point is that a macro lens is designed to provide a sharp image and a flat field (hopefully) at short focus distances. This is not true of traditional lenses even when you put them on an extension tube - at close focus they usually are softer at image center and exhibit potentially extreme field curvature even if they were flat field at longer focal distances.
Aberrations are absolutely dependent on the subject distance/focus setting. This is why "floating element" lens design began to appear in macro designs many decades ago. Using a standard block focus design it was impossible to produce good sharpness at both near a far distance settings. You had to design the lens so that element groups moved relative to each other to control aberrations at both short and long focus.
https://www.opticallimits.com/focusing-systems
https://www.lensrentals.com/blog/2011/02/things-you-should-know-about-your-lenses-but-may-not/2
The guys at Lenstip think, these soft edges at large apertures may be because of the unusual long and slender design of this macro lens. You can read about it in the link to their lens review from 2012 that I provided.
Yes, the drop in sharpness in the corners is really quite clear in the LensTip test. Still even in the corners those are high numbers compared to say a kit zoom center sharpness:
https://www.lenstip.com/334.4-Lens_review-Olympus_M.Zuiko_Digital_12-50_mm_f_3.5-6.3_ED_EZ_Image_resolution.html
Their test method says they use A0, A1, A2 and A3 test charts and average all the results. They make no mention of checking for or correction for field curvature in their tests. So anyway clearly they aren't testing at macro distances at all and it is quite possible the Oly has field curvature at non-macro working distances which is what may cause that fall off in the corners.
Ken W
cba_melbourne
Err, I still do not think so. If a lens has say field curvature, the effects of curvature will be present at any focus distance. If a lens has soft edges, this will be present at any focus distance, etc.
Changing the aperture will of course affect sharpness.
With lenses that move only one single element for focusing, there may be a very small difference in sharpness at different focus distances. But I think this will be a very minor difference, compared to the effects of aperture and other aberrations.
kenw
No, flat out 100% absolutely wrong. See links in my post (which I was probably cross posting so you didn't see before making yours).
Ken W
cba_melbourne
I see. Makes perfect sense now. Thanks for putting me right , I learned something today.
