M100 grip
Started Jan 9, 2021 | Discussions
Mrfm Forum Member • Posts: 53
M100 grip
Another question if I may. This camera is difficult to hold. Does anyone use an adhesive grip similar to those used for the rx100 on this camera?
I want to keep the bulk down so didn't want a large screw on grip..
Canon EOS M100 Sony RX1 Sony RX100
Rock and Rollei Senior Member • Posts: 2,899
Re: M100 grip
I considered it, but bought a wrist strap instead, which does the same thing for me.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
m100
m100 Senior Member • Posts: 2,048
Re: M100 grip
https://www.youtube.com/watch?v=zqPBmOTIjIE
" It's a virus that hitches a ride on our love and our trust for other people. "
Dr. Celine Gounder
 m100's gear list:m100's gear list
Canon EOS M6 II
OP Mrfm Forum Member • Posts: 53
Re: M100 grip
That's great i think I'll try that
If it works I might sell them as special limited edition grips for Leica cameras for about £35 a set. I'll make a fortune!
GreatOceanSoftware
GreatOceanSoftware Senior Member • Posts: 1,215
Re: M100 grip
FWIW, I considered the M200 for a while as a travel option. I knew that I wouldn’t like it without a grip after holding one in a store, so I did a little research. I stumbled across the adhesive grip for the small Sonys, and printed a photo of the grip to exact scale. I cut it out and overlaid it on an exact scale frontal view of the camera and it seemed to be a good fit.
As I recall it was fairly inexpensive and was resolved to give it a try if I bought the camera.
In the end I wound up with the M6II, but the M100/200s still appeal to me and I may pick up one anyway.
The only thing I obviously couldn’t test was the curvature of the camera body at the side and if that might affect the fit. Again, FWIW.
Randy
 GreatOceanSoftware's gear list:GreatOceanSoftware's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +11 more
Tapik
Tapik Regular Member • Posts: 107
Re: M100 grip
https://shop.usa.canon.com/shop/en/catalog/camera-face-jacket-eh-fj-border-yellow#
there is also things like this, and chinese-knockoffs, that may be even better (lower price and no screw at the bottom)
jkcz Regular Member • Posts: 168
Re: M100 grip
I designed and 3D printed a small stick on grip for mine (similar to the ones from Flipbac), if you have access to a printer I can send you the CAD model if you'd like.
 jkcz's gear list:jkcz's gear list
Canon EOS M100 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +2 more
nnowak Veteran Member • Posts: 9,074
Google
I just Googled "Canon M100 grip" and it looks like there are a lot of options in a variety of sizes and form factors.
Re: M100 grip
thanks all.
ive found the blue version of this on ebay for £4 so figured i couldn't go too wrong with this even if they're not the most attractive.. can't for the life of me work out why they wouldn't have it in black to match the actual camera..
Re: Google
ill keep my eye out for the g3-e3 if i can get it cheap.  i thought it was only sony that conned the rx100 owners with their expensive grips!
bengrulz Junior Member • Posts: 38
Re: M100 grip
I posted this in a similar thread:
For me the Flipbac fit on the camera fine but my fingers felt crowded between the lens and the grip. I ended up taking it off.
I've found this rubberized grip to feel really good, it's minimal enough to fit under cases, adheres strongly, and you can cut to fit and place wherever needed: https://smile.amazon.com/gp/product/B01FLQO5IU/
I've also used the ebay silicone skin grip which offers some protection along with grip but is a bit.. janky/floppy but it's not bad and easily removed: https://www.ebay.com/itm/Silicone-Rubber-Bag-Body-Cover-Case-Skin-For-Canon-Eos-M100-Camera/333247888901
Finally, I've tried the official Canon face jacket which adds decent shape but is a bit plasticy and dry feeling (I tried the yellow one, leather ones are probably better). They're a bit pricey and block the tripod screw, but they are a good fit and remove easily: https://shop.usa.canon.com/shop/en/catalog/camera-face-jacket-eh-fj-border-yellow#
Re: M100 grip
I've taken a risk on bought the canon grip for the m10 for a few pounds on ebay. Hopefully it'll fit.
Thanks for the advice. Lots of very helpful people on here
ipribadi Regular Member • Posts: 489
Re: M100 grip
My reply is too late, but here's what I have on my M100:
https://www.amazon.com/gp/product/B0058BW0LS
 ipribadi's gear list:ipribadi's gear list
Canon EOS M100 Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM +2 more
R2D2 Forum Pro • Posts: 26,528
Re: M100 grip
I know what you mean about the RX100. It’s such a slippery little fish! But the little rubber stick-on grip absolutely transforms the camera’s handling (without adding to the camera’s overall size) . You can one-hand the RX100 now with ease (I have the Mark II).
Something similar would be great for the M100. Heck, for $15 the AGR2 might be worth a try on the M!
R2
ps. If you do get a grip that screws into the tripod mount, be sure not to over-tighten it (the M Series’ bottom plates are not metal and can crack).
pps. Just saw the Flipbac grip that was posted, and that one looks like a good fit.  Hopefully the adhesive is excellent.
sgangker Regular Member • Posts: 119
Re: M100 grip
I too find my M200 a bit difficult to hold. So I bought a Flipbac G4 camera grip to stick on the M200. I feel that it is quite good, more confident of holding the camera with one hand now.
 sgangker's gear list:sgangker's gear list
Canon PowerShot S110 Canon G7 X II Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +5 more
GreatOceanSoftware
Re: M100 grip
Thanks for that. I think we have a winner! Saved it in my wish list.
Randy
Tapik
Re: M100 grip
Is it safe to use grips like this, I mean if I want to remove it - will it be easy enough removal or some glue will still stay on the surface?
Re: M100 grip
You are welcome. But do take note that one of the members has also mentioned that space between the lens and grip is too cramped for the fingers. For my case, I am quite comfortable with the G4 camera grip. But if your fingers are big, you might want to consider other model (Flipbac G1, G2 or G3).
Re: M100 grip
It is stick on using double-sided adhesive tape. So far, the adhesive tape seems quite strong and the grip has not drop out before.
But I have not tried to remove the grip before, so I am not too sure whether it is easy to remove.
GreatOceanSoftware
Re: M100 grip
Nah, won’t bother me. Thanks for the photo. Worth a thousand words 😉
Randy
