X100V - best cap for weather-resistance kit
chrisby
chrisby Regular Member • Posts: 282
Hi,
I read that the original lens cap does not fit very well on the kit filter (49 mm thread). What is the best cap solution? Does any of those snap lens caps, e.g. from Hama fit in the kit filter thread? Any experience?
00095449 Hama "Smart-Snap" Lens Cap, 49 mm | Hama DE
May be there was already a discussion, than I would appriciate a belonging link.
Thank you very much in advance; I could not try in a shop these days
Chris
“Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.”
- Antoine de Saint-Exupéry, Airman's Odyssey -
http://www.dpreview.com/members/5712270407/challenges
 chrisby's gear list:chrisby's gear list
Panasonic Lumix DMC-TS3 Canon PowerShot G1 X Canon G3 X Canon G9 X II Canon G1 X III +8 more
Morris0
Morris0 Forum Pro • Posts: 18,971
Re: X100V - best cap for weather-resistance kit
I have found a size 7.5 New York Yankee cap to fit perfectly!
Morris
Fujifilm X-T3 Samyang 12mm F2.0 NCS CS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Sigma 150-600mm F5-6.3 | C XF 90mm +11 more
DarnGoodPhotos Forum Pro • Posts: 10,806
Any filter will provide weather resistance because the water can't get through the metal threads.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XC 16-50mm F3.5-5.6 OIS +2 more
Les Lammers
Les Lammers Veteran Member • Posts: 3,990
chrisby wrote:
Hi,
Chris
I use this with a UV filter and like it a lot. No lens cap needed.
https://www.amazon.com/Haoge-LH-X49W-Ultra-Thin-Fujifilm-Replaces/dp/B085VHX21Z/ref=sr_1_5?dchild=1&gclid=Cj0KCQiA6Or_BRC_ARIsAPzuer9jfCtezV74wvrn7iDHDxfbvQ6Prm1fORy-dqNmR52bcYJrHeHhM0gaApS2EALw_wcB&hvadid=410002516923&hvdev=c&hvlocphy=9012267&hvnetw=g&hvqmt=b&hvrand=1851744827347969197&hvtargid=kwd-350605189583&hydadcr=18445_11408571&keywords=haoge%2Blens%2Bhood&qid=1610285738&sr=8-5&tag=googhydr-20&th=1
 Les Lammers's gear list:Les Lammers's gear list
Fujifilm FinePix X100 Fujifilm X100V Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-E3 +9 more
Scriv
Scriv Contributing Member • Posts: 931
Get the Nisi filter and use your stock Fuji lens cap.
https://www.amazon.com/dp/B086995LZX/ref=cm_sw_r_cp_apa_i_XE1-FbEA22800
 Scriv's gear list:Scriv's gear list
Sony RX100 V Fujifilm X100V Canon EOS 7D Mark II Canon EOS 5D Mark IV Fujifilm X-T30 +12 more
Erik Baumgartner Senior Member • Posts: 3,444
I like the one piece Haoge filter: WR, great glass (which is recessed and protected), feels great in the hand, it accepts additional 52mm filters or hoods (unlike the Nisi), it’s relatively cheap, and the original cap still fits too.
Haoge LUV-X54W Metal Lens Hood... https://www.amazon.com/dp/B08BZJSTRX?ref=ppx_pop_mob_ap_share
Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R +2 more
MapleLeafBryon Regular Member • Posts: 361
I use the cap that comes with the X100T. Fits with perfect amount of grip. Not sure, but it also may be the same as the one with the X100F.
Bryon
 MapleLeafBryon's gear list:MapleLeafBryon's gear list
Fujifilm X100V
chrisby
OP chrisby Regular Member • Posts: 282
Re: X100V - best cap - Thank You
chrisby wrote:
Hi,
Chris
Thank you all for your input, much appriciated. For the moment the Haoge solution seems to me the favorite, also available in black. Not known to me yet, and I own some 52 mm filters which also speaks for this piece.
However, it is not easy to get an overview of all possible combinations. Not sure whether Fuji creates the optimum here.
Chris
jjcha Regular Member • Posts: 210
I also use one of the Haoge's mentioned above (the circular one, also as linked as follows).
https://www.amazon.com/Haoge-LH-X49W-Ultra-Thin-Fujifilm-Replaces/dp/B01DNL2S98
The lens hood itself helps prevent water from hitting the UV filter screwed inside of it, so you can actually shoot in the rain (to a reasonable degree).
I have an old X100F lens cap which fits on this lens hood.
The lens cap that came with the X100V is actually just a tiny bit wider than the old X100 series lens caps, so is a bit too big for it .
