Using a PC Monitor as an external monitor for DSLR?
Started Jan 8, 2021 | Questions
Charlie_hhh New Member • Posts: 2
Hi there! I was coming across this video where someone used his (old) PC monitor as a bigger live view screen. He mentioned that I needed an HDMI to Mini HDMI adapter (he used a VGA to Mini HDMI though) to connect the camera to the monitor. That is exactly what I did.
Unfortunately, this did not work for me. I have no clue why it does not show up on my monitor. It looks like there is no signal coming from the camera. I have a Canon 200D and for the monitor the Asus VC239H. I bought these:
Adapter HDMI to Mini HDMI
https://www.amazon.com/UGREEN-Compatible-Raspberry-Camcorder-Projector/dp/B00B2HOS08/ref=sr_1_4?dchild=1&keywords=UGREEN+Mini+HDMI+Adapter+naar+HDMI+Kabel+Mini+HDMI&qid=1610113955&sr=8-4
HDMI Cable:
https://www.amazon.com/UGREEN-Braided-Ethernet-Compatible-Computer/dp/B083Q283J8/ref=sr_1_15?dchild=1&keywords=UGREEN+2.0+HDMI+Kabel+4K&qid=1610114017&sr=8-15
If there is someone who could help me, that would be amazing! Thanks in advance!
(This is my first question, if there is something missing please let me know)
Canon EOS Rebel SL2 (EOS 200D / Kiss X9)
mdmarqphoto Senior Member • Posts: 1,460
Re: Using a PC Monitor as an external monitor for DSLR?
Is the correct input selected on the monitor?
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
OP Charlie_hhh New Member • Posts: 2
There is only 1 HDMI port on the monitor, but selecting the HDMI does not show anything. I tried VGA and DVI-D just to try, but of course that did not work as well.
stevet1 Senior Member • Posts: 1,300
Charlie,
Going through a process of elimination, have your tried hooking up another HDMI device to your computer, and/or hooking up your camera to different computer?
That might give you a place to start one way or another.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
rmexpress22 Senior Member • Posts: 2,304
A couple of things I can think of.
If the camera is set to NTSC or PAL, try switching to the other depending on which region you're in.
While it looks like the camera should supported HDMI live view, the manual doesn't mention it. Press play on the camera while the monitor is plugged in and see if anything appears on the monitor. You will have to have a video or picture in the memory card inside the camera, of course.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
