Red and blue dots on 600d
Started Jan 6, 2021 | Discussions
Cagri12 New Member • Posts: 2
I took a picture with lens cap on and 30 seconds and there are a lot of red,white and blue dots it only happens when i shot long exposures but does it a big problem?
Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
Aoi Usagi Veteran Member • Posts: 3,221
Re: Red and blue dots on 600d
This is normal and is not a problem.
Formally Evogt500
Iron Mike
MOD Iron Mike Contributing Member • Posts: 540
These are generally referred to as "hot pixels". The pixels at these positions are stuck and always "on" at a maximum saturated level. It is normal to have several of these and even my 5D mkIV has many. There are two general ways to remove them so that you don't see them:
A) The camera can map out the hot pixels. Remove the lens and cap and put the camera into manual sensor cleaning mode. The mirror will flip up and shutter will open. Let the camera sit and wait 30 seconds and shut the camera off. Take another dark frame and see if the hot pixels are gone.
B) Some software, such as Adobe Lightroom, will remove them as well if you are shooting in raw. This is useful if new hot pixels show up since you last mapped them out: if I'm shooting raw I still don't see them in LR.
Mike
bclaff Forum Pro • Posts: 13,929
It's not unusual for a long exposure.
FWIW, these are not stuck at maximum value; simply over-active.
Black images aren't a good choice to test for "hot" pixels.
If you see problems in any of your normal photography then it's worth looking into.
I can help you perform a reasonable test.
Contact me by email or Private Message (PM) if you'd like that.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
OP Cagri12 New Member • Posts: 2
I can't see any problem at my normal photography and after I put the cam to manuel cleaning mode there aren't much left so it's ok for me.
Thanks, everyone, for your help.
Are you referring to sensor cleaning when you say "manual cleaning mode"?  Because that has nothing to do with noise, stuck, or hot pixels.
Formally Evogt500
On some cameras doing a manual cleaning (or two in succession) also causes the firmware to detect and map out "hot" pixels.
So yes, it does make sense to mention.
This not stated in the manual.  And if true, what happens when some is physically cleaning the sensor?  The sensor will be exposed to all kinds of lights and colors.  How will it know which pixels to remap?
Formally Evogt500
It's a well-known "secret" "back door".
This has nothing to do with physically cleaning. Only asking the camera to self-clean.
Well I just tried your method on a 70D and the results are inconclusive. There was no change. Maybe the 70D doesn't have this feature?  Manual cleaning option on Canon cameras is for physically cleaning the sensor, as stated in the owners manual.
Formally Evogt500
mdmarqphoto Senior Member • Posts: 1,460
I remember reading about this fix when I bought my 70D, and a quick Google search results in many links that say this does indeed work, including several people in this thread:
https://www.dpreview.com/forums/thread/3539961
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
Interesting.  I guess my 70D doesn't think it needs to remap itself, or thinks there are not a large issue with hot pixels.
Formally Evogt500
Inukim Regular Member • Posts: 328
I tired it too and didn't see much difference.  It must be very subtle.
karl mohr Senior Member • Posts: 1,678
10 years ago, I bought a T2i, brand new, and when I got it home it had a brilliant white stuck pixel, or whatever, that was so blatantly obvious that you could noticeably see it in the live-view screen, on the pictures, in the movies.  I did the 'manual clean' and it fixed it right up.  So yes, it is obviously an undocumented feature, but it works.
 karl mohr's gear list:karl mohr's gear list
Canon 6D Mark II Canon EOS 60D Canon EOS 80D Canon EF 17-40mm f/4.0L USM Canon EF-S 55-250mm f/4-5.6 IS +3 more
Also, you may want to turn on long exposure noise reduction....
