R7 Resolution Rumors
Started Jan 6, 2021 | Polls
9VIII Senior Member • Posts: 1,331
http://thenewcamera.com/canon-eos-r7-rumored-specification/
Report is Canon is testing multiple sensors in the R7 body, which one do you think they should choose to release?
 9VIII's gear list:9VIII's gear list
Canon EOS 1100D Fujifilm X-E2S Fujifilm X-E3 Canon EF 400mm f/5.6L USM Sigma 150mm F2.8 EX DG Macro HSM +7 more
POLL
20MP
14.6% 12  votes
32.5MP
74.4% 61  votes
45MP
8.5% 7  votes
Both 20MP and 45MP Variants
2.4% 2  votes
  Show results
Canon EOS 7D Mark II
BirdShooter7 Veteran Member • Posts: 9,127
Re: R7 Resolution Rumors
I found 45 MP at 20fps became burdensome when I rented the R5 so if Canon does give 45 MP I hope they give an option to reduce the FPS in ES mode to say 10 or so.  Otherwise I think the 32MP sensor is a pretty good compromise.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
MikeJ9116 Veteran Member • Posts: 6,955
I think their current flagship APS-C sensor will be used with faster readout and some other tweaks.
moon1029 Regular Member • Posts: 304
asp-c 45mp would be unusable above ISO 6400
Continuous shooting speed used to be what differentiates the 7D series from the 5D series. But now the R5/R6 has 12fps and top-notch AF. An asp-c R camera seems much less attractive except for a lower price.
 moon1029's gear list:moon1029's gear list
Canon EOS R5 Canon EOS R6 Canon 85mm F1.4L IS USM Canon RF 15-35mm F2.8L IS USM Canon RF 70-200 F4 L +6 more
While some people see the 1.6X crop of an APS-C sensor as a disadvantage, a lot of people see it as a big advantage.  A 32mp APS-C sensor puts a lot more pixels on the target than a 45mp FF sensor.  For me, an additional attraction of an RF mount APS-C camera is I can adapt the very good, small, lightweight EF-S lenses I own to it.
Steve Balcombe Forum Pro • Posts: 15,571
This is not so much a rumour as the same intelligent guess that any rational person would make. R6 body (though personally I would prefer R5, especially the viewfinder), R6 performance, with an update of the already-excellent 90D sensor. IBIS of course. £/€/$2,250, maybe a bit more.
Canon is sometimes accused of being unimaginative, and in this case that's just fine.
Edit: I'm not sure whether a CFexpress card is needed for 12/20fps at 32.5 MP and a buffer of at least a couple of hundred frames. But if it is, then that's another reason to get close to the R5 body. This has to be a high-performance body to justify its existence.
sportyaccordy Forum Pro • Posts: 20,562
I feel like a 45MP R7 will cost more than the R5 due to the worse economies of scale.
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
ProDude Senior Member • Posts: 4,851
Most agree as I do, the 32mp would be the best compromise and satisfy the largest number of people who are prospects for this camera. It would allow for more cropping but keep the speed up.
Name the gear and I've probably owned it and used it.
justmeMN Forum Pro • Posts: 10,706
Canon's 32.5MP APS-C sensor is underutilized. It's the logical choice.
fredlord
fredlord Veteran Member • Posts: 3,303
Wouldn't a 45mp crop sensor be the equivalent of 115mp full-frame sensor? If so, it would be all new territory.
The 90D sensor is awfully good and would make a good size for the R7.
 fredlord's gear list:fredlord's gear list
Canon EOS R5 Canon EOS R7 Canon TS-E 17mm f/4L Canon EF 100mm F2.8L Macro IS USM Sigma 15mm F2.8 EX DG Diagonal Fisheye +13 more
Frodro100
Frodro100 Regular Member • Posts: 386
The 32.5MP sensor would be logical. They put that into the 90D and M6 Mark II and it seems to be a really capable sensor in those bodies. The philosophy of an R7 with such a sensor might be something in between those two models but taken a step further--the full-time electronic viewfinder and AF tracking capabilities (while using the viewfinder) of mirrorless, but the ergonomics of an SLR-shaped body. Add in a buffer like what's found on the R6/R5 and the price of the R (or maybe less) and I think they'd have a winner.
thunder storm Forum Pro • Posts: 10,139
Isn't ef-s glass getting a bit too outdated already to make an 32Mp aps-c sensor more interesting than a full frame sensor?
I can think of 2 crop lenses - the sigma 56mm f/1.4 and the Canon 32mm f/1.4 - , but those have the ef-m mount. There are other relatively compact lenses on crop, but those cover the full frame circle too.  The sigma f/1.8 zooms? These are crop lense, but not compact at all.
Would the ef-s 24mm f/2.8 stm be better on a 32Mp crop sensor than the RF 35mm f/1.8 is stm on a full frame sensor? I don't think so. Yes, the 24mm is a pancake, but with the adapter that advantage has gone.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
I will find out if an RF mount APS-C camera is released. So far they are plenty good for a 24mp sensor and 32mp isn't all that far off. I think they will do fine for my needs.
I expect there will be plenty of 2nd party RF lenses over time. It seems like some people think the RF lens catalog is frozen when it will keep growing and maturing over time.
I think, in general, crop lenses provide a better balance of performance versus weight and size than using FF glass. There are some exceptions but those lenses usually are not stabilized. If an R7 does show it should have IBIS which will help a lot with adapting several of EF the primes I use.
Jotoco Regular Member • Posts: 233
I don't think even the new RF glass can resolve 45mpx crop sensor.  That is just too demanding.
 Jotoco's gear list:Jotoco's gear list
Canon EOS M50 Canon EOS RP Canon EF 85mm F1.8 USM Canon EF 17-40mm f/4.0L USM Canon EF-M 22mm f/2 STM +5 more
I would faint and fall out of my seat if Canon put out a 45mp APS-C sensor.
lighthunter80
lighthunter80 Contributing Member • Posts: 990
I reckon an R7 would be targeted at photographers who want speed and reach. 20MP would be underwhelming and Canon already has a 32MP sensor for APSC.
I am not sure about lenses though. The current RF line up is not very attractive for APSC. They should come out with at least a suitable kit lens.
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
I probably would too but then I was pretty surprised by the 32MP one so who knows.
That will be another 700 threads about how the new r7 focus is "soft", like the 90d. The glass is just not sharp enough.
quiquae Senior Member • Posts: 2,265
The rumored RF 18-45 would fit the bill for a crop standard zoom, if a bit short on the long end, and the already-released 70-200/100-500 would be great long telephoto lenses on crop. They need to do something about the 45-70mm gap, though: carrying an 18-45 and 24-70 or 24-105 together doesn’t sound terribly elegant. Perhaps this may be a good time for Sigma to step in with a 50-150F2.8?
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
OP 9VIII Senior Member • Posts: 1,331
There is really no need to have dedicated APS-C glass on RF mount if all the bodies are going to have IBIS, Canon has the opportunity to assume they can use all the space of a 35mm sensor for stabilization.
